R56 R56 Axle Shafts
Old Feb 19, 2014 | 08:59 AM
Porthos's Avatar
Porthos
R56 Axle Shafts
Long time since I have posted but, I am soon to be home from a deployment and need to fix a couple of things. As we all know lowered MINIs tend to eat axles and mine were starting to squeak when turning after lowering my MINI. I am also getting some binding when turning out of a down slope. I was wondering if anyone can point me in the right direction for axle shafts that don't cost a freaking fortune but, are still good shafts?
Old Feb 19, 2014 | 09:27 AM
Agbullet25's Avatar
Agbullet25
I've seen these guys mentioned a couple times here on the forums. They don't list specific part numbers for the MINI, but they seem to be real easy to get in touch with to discuss your needs and get a quote.
www.raxles.com
Old Feb 19, 2014 | 09:46 AM
Porthos's Avatar
Porthos
I wish I had known about this place before leaving Florida. I could have gone to their shop. Thanks i will contact them and see what they can do.
Old Mar 1, 2014 | 02:21 PM
Porthos's Avatar
Porthos
I looked into that company and they do not make MINI axles. Does anyone have another place that does axles?
Old Mar 1, 2014 | 05:28 PM
TazMinianDevil's Avatar
TazMinianDevil
I thought Detroit Tuned sells a replacement set.
Old Mar 1, 2014 | 07:43 PM
Porthos's Avatar
Porthos
I was looking for axles that doesn't cost $500 a piece and were also uprated.
Old Mar 1, 2014 | 08:21 PM
Agbullet25's Avatar
Agbullet25
The only set I saw at DT were for the R53
Old Mar 1, 2014 | 09:23 PM
Porthos's Avatar
Porthos
Damn this sucks. I really doubt wasn't too drop a grand I new stock axles.
Sent from me being awesome around my MINI!!
Old Mar 2, 2014 | 03:25 AM
CFMINI's Avatar
CFMINI
The Drive Shaft Shop in NC only shows R53 axles on their web site. I have their level 2.9 475 whp rated axles on my heavily modded R53. At $875 they are actually cheaper than stock MINI axles. and "uprated " means much larger and stronger CV joints and better axle material. You should talk to them about coming up with a R56 axle. But be careful as the axles I got were wrong at first - a ground surface was .003 too large - had to send them back so they could fix that - but they did pick up the shipping both ways.
Old Mar 2, 2014 | 03:26 AM
scubbysnacks's Avatar
scubbysnacks
Dang son, usually venders jump all over a threads like this when theres talk of spending cash, looks like your in a world of hurt. Good luck.
Old Mar 2, 2014 | 08:09 AM
Porthos's Avatar
Porthos
Yeah I talked to them but, they didntb sound interested in doing axles for the R56. I will ask them again and see what I can work out.
Old Mar 2, 2014 | 04:18 PM
mattkosem's Avatar
mattkosem
Driveshaft Shop told me, in order for them to make a set, they'd need a set of fresh axles and $1200 to make a set of 2.9s.
--Matt
Old Mar 2, 2014 | 04:23 PM
Porthos's Avatar
Porthos
Yeah nevermind then that ain't happening.
Old Apr 23, 2015 | 12:38 PM
Msink's Avatar
Msink
And I'm shocked I haven't gotten even 1 reply to my first post here after over 350 views.
https://www.northamericanmotoring.co...et-option.html
Stock Axles are $1600-$1800 a pair. These guys sell R53 axels for 1/4 that! Do folks really see no need for an alternative for the R56?!
Old Apr 24, 2015 | 01:51 AM
Systemlord's Avatar
Systemlord
In the 2 years since I have been a member I can remember maybe 2 threads about needing replacement axles.
Old Apr 24, 2015 | 05:27 AM
v10climber's Avatar
v10climber
You're way over-pricing stock axles. They're still like $1150 for a set which isn't cheap but it's quite a bit less than 1600-1800
http://www.ecstuning.com/Mini-2010-C...les/ES2584741/
Unless you're getting vibrations from lowering I've not heard of anyone breaking axles. When we sold our mini it had over 1000 auto-x launches and a bunch of drag launches from pro solo. Some of those on r-compound tires. We had absolutely no issues with the axles.
Old Apr 24, 2015 | 08:30 AM
Yea, mostly Gen 1 MINIs replacing axles , but most from damage on poor roads / wreaked or a ton of miles.
Not any aftermarket options for the Gen 2 Yet:
2007 MCS Gen 2
http://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Drivetrain/Axles/
Old Apr 24, 2015 | 11:23 AM
Systemlord's Avatar
Systemlord
When you disconnect either left or right R56 axles does the transmission drain its trans fluid or is it sealed? Occasionally I get extreme vibration from the driver side and feels pretty intense like somethings unbalanced, since the first occurrence it's happening less and less as time goes on. It first started when I traveled to a city with the worst roads I have ever encountered! Wheel and hub bearings look fine, truly strange!
Old Apr 24, 2015 | 11:32 AM
Grizld700's Avatar
Grizld700
I had to disconnect the drivers side last weekend when I was doing the control arm bushings and outer ball joints because I found a loose boot clamp on the inside boot. A small amount drained out. I had some extra from when I drain and refilled it last year. It didn't really amount to much though. 1/4 - 1/2 cup maybe.
Old Apr 24, 2015 | 12:59 PM
Systemlord's Avatar
Systemlord
Do you know what it looks like when the boots are removed? Typical U-joint?
Old Apr 24, 2015 | 01:37 PM
Grizld700's Avatar
Grizld700
Its a triple type on the inside of the boot. If you look at the housing in this picture, you should have an idea:
Old Apr 24, 2015 | 01:44 PM
ammodave's Avatar
ammodave
How about remanufactured axles like this: http://www.partsgeek.com/catalog/2010/mini/cooper/driveshaft_-ar-_axle/axle_assembly.html?
Old Apr 25, 2015 | 03:26 PM
Systemlord's Avatar
Systemlord
A triple what? I have no clue what it looks like inside an axles pivot joint.
Originally Posted by ammodave
How much dependability and reliable can a $159.17 remanufactured axle be? I'd rather buy a new OEM axle.
Old Apr 25, 2015 | 03:49 PM
Slave to Felines's Avatar
Slave to Felines
https://www.google.com/search?q=trip...w=1337&bih=737
Old Apr 25, 2015 | 06:08 PM
Msink's Avatar
Msink
That's because the threads aren't about axle replacement (the solution), but vibrations (the problem) Plenty of threads on this.
Google:
lowered mini cooper vibrating site:www.northamericanmotoring.com
The mini I had lowered was vibrating immediately from a simple h&r install. Guess I'll be going about this on my own then.
