engine noise from driver's side
Old Feb 14, 2014 | 12:23 PM
notsoMINI_r55's Avatar
notsoMINI_r55
Hi,
I was hoping to get some insight into some noise i've been hearing, maybe by trying to describe it someone has had a similar issue and can help me out. I have a 2010 r55 non s. Noise sounds like somethings loose on driver's side (engine compartment), makes noise when going over rough road at any speed, though more so when at slower speeds. Noise persists even when engine has warmed up and it does not get worse or better. Does not always make noise when going over rough terrain.
thanks for reading
Old Feb 26, 2014 | 06:25 PM
Blind Dog Daddy
Check the air filter box and connecting parts, filter box is snapped onto 2 posts with rubber grommets. I've seen the grommets misplaced or missing. The intake box attachment to the air filter box could also be loose at the joining tabs.
Old Mar 9, 2014 | 03:38 AM
cambo's Avatar
cambo
hey notsomini...any update on this? Did you figure out what it was?
I've noticed the same sort of noise over the past couple weeks. It comes and goes...cold start, warm start...doesn't matter.
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
bugeye1031
Aug 15, 2015 08:14 AM
Minibeagle
Aug 13, 2015 10:00 AM
