North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-188/)
-   -   engine noise from driver's side (https://www.northamericanmotoring.com/forums/stock-problems-issues/265457-engine-noise-from-drivers-side.html)
notsoMINI_r55 Feb 14, 2014 12:23 PM
Hi,
I was hoping to get some insight into some noise i've been hearing, maybe by trying to describe it someone has had a similar issue and can help me out. I have a 2010 r55 non s. Noise sounds like somethings loose on driver's side (engine compartment), makes noise when going over rough road at any speed, though more so when at slower speeds. Noise persists even when engine has warmed up and it does not get worse or better. Does not always make noise when going over rough terrain.
thanks for reading :)
Blind Dog Daddy Feb 26, 2014 06:25 PM
Check the air filter box and connecting parts, filter box is snapped onto 2 posts with rubber grommets. I've seen the grommets misplaced or missing. The intake box attachment to the air filter box could also be loose at the joining tabs.
cambo Mar 9, 2014 03:38 AM
hey notsomini...any update on this? Did you figure out what it was?
I've noticed the same sort of noise over the past couple weeks. It comes and goes...cold start, warm start...doesn't matter.
