R52 What is this code?
Old Feb 4, 2014 | 05:59 PM
AMink's Avatar
AMink
What is this code?
I have been having odd acceleration for quite some time. It feels like turbo lag when the engine finally kicks in. I have a supercharged engine so it's not turbo lag. Any way, the CEL keeps coming on and going off after three starts. I can actually get the light to turn on when coming down a shallow hill in 6th with no throttle. Took it in to the dealer and the paper says:
001237 DME: Pressure sensor, intake manifold before compressor- input low
The dealer had no offhand idea for what may cause this and I have an appointment scheduled. Obviously I'd like to avoid that and the accompanying cost. Any thoughts on what could cause this code to be thrown? I was hoping it would be something as simple as the MAP or TMAP sensor being bad but I don't want to start replacing parts without direction.
Thanks!
Old Feb 13, 2014 | 07:51 PM
AMink's Avatar
AMink
I also noticed the light only comes on when the temperature is about 40° or less. Any ideas?
Old Feb 13, 2014 | 09:12 PM
Fly'n Brick's Avatar
Fly'n Brick
This may help.
P1237 Secondary Upstream Manifold Air Pressure Sensor Low Input
http://www.minicarparts.net/PDF/MR5E...0825-234V1.pdf
And item #09 on the diagram on 'realoem'.
http://www.realoem.com/bmw/showparts...91&hg=11&fg=40
Old Feb 14, 2014 | 05:10 AM
AMink's Avatar
AMink
Originally Posted by Fly'n Brick
This may help.
Thanks Brick. Do you know if the specifically means the sensor is bad or if it means something is wrong and the sensor is reading it? For $68 I might just try replacing the sensor and see what happens.
Old Feb 14, 2014 | 05:58 AM
Some have attributed that code with others to a vacuum leak , but that was for both codes. Check the intake hose connections first and anything visual then you can narrow it down.
https://www.northamericanmotoring.co...and-p1237.html
For the Gen 1 Cooper S / JCW.
Here is the TMAP sensor near : (manifold) map is near the manifold
#9 http://www.ecstuning.com/Search/SiteSearch/12140872679/
and the MAP (above t-stat)
http://www.ecstuning.com/Search/SiteSearch/12140872648/
Old Feb 14, 2014 | 06:22 AM
AMink's Avatar
AMink
I have pulled both the MAP and TMAP to see if they had any obvious damage. The one on the front of the engine had a lot of oil on it. I cleaned it but it didn't make any difference. Will continue with leak checks.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
