R56 r56 Timing Help
Old Feb 2, 2014 | 12:17 AM
NeverL8's Avatar
NeverL8
r56 Timing Help
Hey everyone! I'm brand new to this site and a first time Mini owner. I love my MCS and I'm wanting it to last for long time. So, had anyone heard of Metal Timing Chain Guides? I'd pay a lot extra to use them over plastic. Thanks everyone for your help in advance.
Old Feb 2, 2014 | 12:37 AM
ZIPPY "S"'s Avatar
ZIPPY "S"
Im not sure they make metal guides. Maybe someone else can chime in with that info. But what usually cases them to fail is the tensioner failing. the lose chain then slaps around and wears them and breaks them off. I can understand your theory thinking metal guides would be better or something stronger anyways. Good luck.
Old Feb 2, 2014 | 06:17 AM
zrickety's Avatar
zrickety
Just get the updated parts from the dealer, you should be covered in the campaign. Ours was just done at 95k. Then do 5k oil changes and you should be good.
Old Feb 2, 2014 | 08:25 AM
NeverL8's Avatar
NeverL8
I took my car in to see about the recall and I guess mine doesn't qualify for it. As for the oil change interval, heck yeah man. I'm using Mini oil and aiming for 4k just like every vehicle I've owned. I want it to last!
Old Feb 2, 2014 | 09:17 AM
ZIPPY "S"'s Avatar
ZIPPY "S"
Sometimes you need to really push to be covered under the campaign recall. Get MINIUSA involved that type of thing. Explain to them your issues. Also some dealers don't seem to be up on the latest recall per say. What year MINI do you have? What issues do you currently have?
Old Feb 2, 2014 | 09:37 AM
NeverL8's Avatar
NeverL8
Okay I'll try some more research. I have a 2007 MCS with 58k on it. So far I don't have issues with it. It has a little tick at cold start but nothing major.
Old Feb 2, 2014 | 09:53 AM
ZIPPY "S"'s Avatar
ZIPPY "S"
Its good to keep your eye on it. Are you the original owner?
Old Feb 2, 2014 | 10:15 AM
NeverL8's Avatar
NeverL8
No I'm the 2nd. I picked it up at 55k. But the owner before me was meticulous about her upkeep. The protective stickers were still on the "Mini Cooper S" door jams.
Old Feb 2, 2014 | 11:04 AM
ZIPPY "S"'s Avatar
ZIPPY "S"
Sounds like you got a nice MINI. What you can do is go to a dealer and have a service print out done on your car. This will tell you what all has been done to your car. See if the timing chain was replaced or the tensioner has been replaced with the newer type. Plus its good to see what has been all done to your MINI. Usually when the timing chain is getting bad you hear more of a growl. Im not sure about a ticking sound. But also you are probably getting close to needing a carbon cleaning. But honestly sounds like your car is running just fine. If you really worried about your timing chain you can have it checked to see how much play is in it. But of course there is a cost to have that done at the dealership. Or as some call it the stealership! Good luck and post some pics of your MINI if you haven't already done so! Enjoy
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
