Ambient Mood Lighting - Cycling through colors at door open.
Old Jan 27, 2014 | 09:34 AM
x2boxers
Has anyone been able to stop the ambient lighting from cycling through all colors when you open the car doors?
I have a 2014 Clubman and have been searching for the answer to this.
I have the lights set on red, but when you open the doors to get in the lights cycle through all colors and then stop back on the red. Can this be changed? I want it to stay on the color I have selected when the doors are opened.
I have even contacted my MA about this and so far he has not been able to answer. Do they all do this after the 2011?
x2boxers
Old Jan 27, 2014 | 02:23 PM
minirab's Avatar
minirab
I have a 2012 R58 and the color doesn't change, door open or closed.
Old Jan 27, 2014 | 04:10 PM
whaap's Avatar
whaap
Did you search the owners manual. I'm betting you'll find the answer.
Old Jan 27, 2014 | 04:23 PM
AZdsrt's Avatar
AZdsrt
I really haven't paid much attention to the ambient lighting on our MCS. Was curious so I looked it up in the manual -
The color and brightness of the ambient lighting
can be changed.
> Press the switch forward.
The color changes in stages.
> Press the switch toward the rear.
The brightness changes in stages.
Intermediate settings and colors are possible.
For a continuous color change in the
ambient lighting, press and hold the
switch forward for longer than 10 seconds.<
Manual not a lot of help (big surprise?), but the last sentence would leave me to believe there is some way to turn off the continuous color change. Sorry I'm not much help, maybe do the 10 sec press and see it it turns it off.
Old Jan 27, 2014 | 08:01 PM
x2boxers
The owners manual only says about pushing the switch forward for ten seconds to get a continuous color change all the time when the car is on.
Mine only changes when I unlock and open the doors. It then cycles through once and stops at the color that I have the lights set on.
By Minirab saying that their coupe color does not change tells me it is possible to change it, but how?
Old Jan 27, 2014 | 09:20 PM
Slave to Felines's Avatar
Slave to Felines
I wonder if there's a setting in the vehicle management system that NCSExpert could change?
Old Jan 28, 2014 | 06:46 AM
Think it was on the 2013+ the color rotate a little then return to the color that was pre-selected. In you case red. When you open the door. Don't think you can turn that off. On 8/2010 cars the color spectrum ( added more colors ) was increased and the " disco mode" as I call it or rotating lights was added, this by holding the toggle forward for ten seconds. . Also you can dim them down and up.
Old Jan 28, 2014 | 08:31 AM
x2boxers
Thanks, can anyone with a 2013+ confirm that your lights do the same thing?
Old Jan 28, 2014 | 08:33 AM
danjreed's Avatar
danjreed
Yes mine do.
Old Jan 28, 2014 | 08:35 AM
whaap's Avatar
whaap
I have a '13 and never did the 10 second thing to rotate the colors. I picked the one I wanted and left it there. It's the only color that ever comes on.
Old Jan 28, 2014 | 11:12 AM
x2boxers
So whaap even when you unlock/open the doors the color stays the same?
There must be a way to change it.
Old Jan 28, 2014 | 11:35 AM
cerenkov's Avatar
cerenkov
So whaap even when you unlock/open the doors the color stays the same? There must be a way to change it.
This was discussed in another thread. Try searching for "disco". Mine cycles when I open the door, I also want to freeze it on one color but have been too lazy to figure it out.
Old Jan 28, 2014 | 04:37 PM
batdevice_'s Avatar
batdevice_
My 2013 JCW Hardtop does this. I don't like it either. Not a fan of seeing purple and pinkish lights flashing when I open the door.
Old Jan 30, 2014 | 10:33 AM
blucrsr's Avatar
blucrsr
Mine only does this after unlocking the doors. So if my doors haven't been locked and I open them, there is no color cycle. Simple solution (which I know isn't a real solution) - never lock your doors!
Old Feb 4, 2014 | 12:55 PM
rckrzy1's Avatar
rckrzy1
yep my 2013 clubbie does that
Old Feb 11, 2014 | 09:57 AM
x2boxers
Well it sounds like they all do this. Only Whapp said otherwise and it was not confirmed. I got an email from my MA (he has also been looking into this) and he says as far as he can find out there is no way to change it and they all do it. I still have hope, but unless someone confirms that theirs does not do it. I am not going to let it make me nuts.
Old Feb 11, 2014 | 09:28 PM
Kevdog's Avatar
Kevdog
I've been going through Mini's website for Germany trying to get Mini's wording for the ambient lighting in German. This could help me locate the setting. I'm guessing the setting will have "LED" in the line. If anyone here with a 2013 or 2014 has access to NCSExpert and can read their FRM module, I will compare it to my settings. Just send me your TRC file. Some possible settings are in:
ZUWACHS_TASTVERH_FLC_LED which translates to "Growth duty cycle" don't know what FLC is. It can also translate to "Incremental pulse duty". Mine is set to: wert_01
LED_LICHTFUNKTION = LED Light Function. Mine is nicht_aktiv
MIN_TASTVERH_BEL_FLC_LED May work together with the first setting. Also set to: wert_01
I will compare every line in the file and note every difference I find (it's only 24K). I really can't believe this feature would be a hardware difference. It is probably a different wert or aktiv/nicht_aktiv setting.
Old Feb 12, 2014 | 02:37 AM
cerenkov's Avatar
cerenkov
You can have my trc file. At the very end there is a setting:
WELCOME_SCENARIO_ACTIVE
aktiv
Here's my file:
CAN_11H
nicht_aktiv
IBUS_R_GANG
nicht_aktiv
IK_BUS_TEILNEMER
nicht_aktiv
ERR_SCHWENK_R_IGNORIEREN
nicht_aktiv
KLS_BEI_AL_AKTIV
nicht_aktiv
ALC_EINSCHALTBEDINGUNG
wert_01
ALC_SCHWENK_LATCH
aktiv
ERR_LWR_L_IGNORIEREN
nicht_aktiv
ERR_SCHWENK_L_IGNORIEREN
nicht_aktiv
ERR_LWR_R_IGNORIEREN
nicht_aktiv
KEINE_L_R_SYNCHRONISATION
nicht_aktiv
CHECK_FGN_SMC_ALC_OFF
aktiv
CHECK_SMC_ERROR
aktiv
CKM_ALC_DEF
wert_16
ABSTELLPOS_SMC
aktiv
BLEND_CHECK_IST_WINKEL
aktiv
BLEND_CHECK_SOLL_WINKEL
nicht_aktiv
CKM_ALC
wert_16
MAX_SW_SCHWENK_W_INNEN
wert_16
MAX_SW_SCHWENK_V_HORIZ
wert_16
MAX_SW_SCHWENK_V_VERTI
wert_16
MIN_SW_SCHWENK_V_VERTI
wert_16
ABSTELLPOS_CUSTOM
nicht_aktiv
TAU_ABSCHWAECHUNG
wert_16
LICHTZ_R_L_FAKTOR
wert_16
SW_NULL_BEREICH
wert_16
V_LO_SW_MITLENKEN
wert_16
V_HI_SW_MITLENKEN
wert_16
V_LO_SW_NACH_INNEN
wert_16
V_HI_AENDER_LENK_UEBERS
wert_16
V_HI_SW_NACH_INNEN
wert_16
KENNL_MAX_UEBERST
wert_16
KENNL_REDUZ_MAX_SCHWENK
wert_16
T_FILTER_V_VEH
wert_16
T_FILTER_UEBERST
wert_16
V_LO_AENDER_LENK_UEBERS
wert_16
V_LO_RED_SCHWENK_W
wert_16
V_HI_RED_SCHWENK_W
wert_16
ABSCHW_D_TAU_LO
wert_16
ABSCHW_D_TAU_HI
wert_16
KLASSIF_UEBERST_ENA
aktiv
V_LO_ABSCHW_D_TAU
wert_16
V_HI_ABSCHW_D_TAU
wert_16
OHNE_GIERRATE
nicht_aktiv
REDUZIERUNG_V_SCHWENK_HI
wert_16
V_REFERENZLAUF_EN
wert_16
KLASSIF_LENKM_ENA
aktiv
KLASSIF_DRIFT_ENA
aktiv
MIN_SW_SCHWENK_V_HORIZ
wert_16
AEND_V_SCHWENK_N_AUSSEN
wert_16
REDUZIERUNG_V_SCHWENK_LO
wert_16
MAX_DELTA_KEINE_VERR
wert_16
T_FILTER_LENKWINKEL
wert_16
V_HI_REDUZIER_V_SCHWENK
wert_16
MAX_VERRINGERUNG_V_SCHW
wert_16
MIN_DELTA_MAX_VERR
wert_16
D_TAU_MITTEL_LENKW
wert_16
T_FILTER_GIERRATE
wert_16
D_TAU_MITTEL_GIERR
wert_16
V_LO_TAU_GIERRATE
wert_16
T_FILTER_TAU_LW
wert_16
V_HI_TAU_GIERRATE
wert_16
T_F_GIERRATE_DEF
wert_16
SCHW_TAU_LW_GR
wert_16
T_FILTER_DYN_LZ
wert_16
DRIFT_INKR
wert_16
DRIFT_DEKR
wert_16
DRIFT_SCHWELLE
wert_16
RAUSCH
wert_16
ZEITK_TRIGGER1
wert_16
MERKM_1_MAX
wert_16
MERKM_1_BEGR
wert_16
ALC_SCHW_GRAD_SCHLECHTWEG
wert_01
MERKM_1_INKR
wert_16
MERKM_1_DEKR
wert_16
ALC_GRADIENT_SCHLECHTWEG
nicht_aktiv
LWR_ABSTELLPOS
wert_01
MAX_SCHWENK_V_H_BEGR
wert_16
VERHALTEN_UEBERWACHUNG
wert_01
KURZSCHLUSS_ENTPRELL
wert_01
KURZSCHL_WIERHOL_ZAEHLER
wert_01
KURZSCHLUSS_CHECK_TIME
wert_01
LENKWINKEL_UEBERSCHREITEN
wert_01
LENKWINKEL_UNTERSCHREITEN
wert_01
WELCOMELIGHT_CKM_3
aktiv
LENKSTOCK_UMSCHALT_VERZ
wert_01
U_POTI_DIMM_MIN
wert_01
U_POTI_DIMM_DELTA
wert_01
HEIMLEUCHTEN_ENABLE
aktiv
MELDUNG_AENDERUNG_DIMMER
wert_01
POTI_DIMM_INVERS
aktiv
POTI_LWR_INVERS
nicht_aktiv
HEIMLEUCHTEN_ABBRUCH
nicht_aktiv
HEIMLEUCHTEN_VERLAENG
nicht_aktiv
HEIMLEUCHTEN
wert_01
WARNBLK_ENERGY_SAVE_MODE
aktiv
DEF_HEIMLEUCHTEN_CKM
wert_02
UNP_HEIMLEUCHTEN_CKM
wert_02
AUTOM_LICHT_ABSCHALTUNG
nicht_aktiv
CODIERINDEX_FRM
wert_01
MAX_BETAETIGUNG_FOMEHO
wert_02
CRASH_WARNBLINKEN
aktiv
CBD_ZEICHN_INDEX
wert_01
SL_SCHALT_UMSCHALT_OPT
300_ms
CRASH_58G_EIN
aktiv
ENERGIE_UBATT_LIMIT
wert_01
WERT_CRASHVERHALTEN
wert_01
TIPP_BLK_LOESCHT_IMMER
aktiv
WELCOMELIGHT_CKM_2
aktiv
COLORTABLE
wert_01
NOTLAUF_FKT_SCHALTERSTELL
aktiv
NOTLAUF_FKT_GESCHW
wert_01
NOTLAUF_FKT_TIMER
wert_01
COLORSWITCH_LANGDRUCK
wert_01
ENERGIE_ZEIT_LIMIT
wert_01
TIME_PER_STEP
wert_01
ENERGIE_ZEIT_ENTPRELL
wert_01
LWR_MAX_POS_NORM
wert_01
LWR_MAX_POS_REF
wert_01
LOAD_DUMP_MAX_TIME
wert_01
LOAD_DUMP_PRELL
wert_03
UMSCHALTOPT_LICHTSCHALTER
wert_02
U_LWR_POTI_STELLUNG_2
wert_01
HALB/VOLLSCHRITT
halbschritt
LWR_TESTBETRIEB
nicht_aktiv
LWR_SCHRITTE_STELLUNG_0
wert_03
U_LWR_POTI_STELLUNG_0
wert_01
U_LWR_POTI_STELLUNG_1
wert_01
LWR_SCHRITTABSTAND_GRENZE
wert_01
LWR_TEMPERATUR_GRENZE
grad_-20
FL_ASSIST_ENABLE
nicht_aktiv
BFD_1_WERT_AX_RUCK
wert_01
VORFELD_BEL_GEDIMMT
aktiv
IB_2MIN_OPTION
aktiv
IB_SOFTON_OPTION
aktiv
FL_ASSIST_FUNKTIONS_ANZ
nicht_aktiv
WARNBLK_ENERGY_SAVE_AHM
aktiv
SMART_BEAM_CKM_1
nicht_aktiv
SMART_BEAM_CKM_2
nicht_aktiv
SMART_BEAM_CKM_3
nicht_aktiv
ASP_LIN_VERBAUT
nicht_aktiv
ASP_KEY_MEM_OHNE_MASTER
nicht_aktiv
U_MIN_TK_SNU
wert_01
DEF_ABBIEGELICHT_CKM
nicht_aktiv
HYST_STAND_KRV
wert_01
FL_ASSIST_ZUST_22_32
nicht_aktiv
UNP_ABBIEGELICHT_CKM
nicht_aktiv
HEIMLEUCHTEN_1
wert_02
HEIMLEUCHTEN_2
wert_02
HEIMLEUCHTEN_3
wert_02
ABBIEGELICHT_CKM_0
nicht_aktiv
ABBIEGELICHT_CKM_1
nicht_aktiv
ABBIEGELICHT_CKM_2
nicht_aktiv
ABBIEGELICHT_CKM_3
nicht_aktiv
DEF_SMART_BEAM_CKM
nicht_aktiv
UNP_SMART_BEAM_CKM
nicht_aktiv
SMART_BEAM_CKM_0
nicht_aktiv
BFD_1_WEGFALL
nicht_aktiv
BFD_1_ENTPRELL_AX
wert_01
DEF_AHL_MODE_CKM
wert_01
UNP_AHL_MODE_CKM
wert_01
AHL_MODE_CKM_0
wert_01
AHL_MODE_CKM_1
wert_01
AHL_MODE_CKM_2
wert_01
AHL_MODE_CKM_3
wert_01
FH_LANGHUB
wert_01
TAU_ABSCHWAECHUNG_SP
wert_16
SW_NULL_BEREICH_SP
wert_16
T_FILTER_UEBERST_SP
wert_16
V_LO_SW_MITLENKEN_SP
wert_16
V_HI_SW_MITLENKEN_SP
wert_16
V_LO_SW_NACH_INNEN_SP
wert_16
H_SENSOREN_UEBER_FCAN
nicht_aktiv
SCHRITTABSTAND_STARTPHASE
wert_01
LWR_TREIBER_CODIERUNG_2
wert_01
NACHLAUF_KLEMME_VA
wert_01
BFD_1_THERM_TIMEOUT
wert_02
BFD_1_MIN_GESCHW
wert_01
BFD_1_STUFE_DELAY
wert_01
BFD_1_BLINK_FREQ_AUS
wert_01
BFD_1_BLINK_FREQ_EIN
wert_01
BFD_1_ENTPRELL_ABS
wert_01
ZEIT_PARKL_AKTIVIERUNG
wert_02
WELCOMELIGHT_CKM_1
aktiv
WELCOMELIGHT_CKM_0
aktiv
KL_VA_EIN_BEI_ENTRIEGELN
aktiv
V_HI_SW_NACH_INNEN_SP
wert_16
KENNL_MAX_UEBERST_SP
wert_16
KENNL_REDUZ_MAX_SCHWEN_SP
wert_16
V_LO_AENDER_LENK_UEBER_SP
wert_16
V_HI_AENDER_LENK_UEBER_SP
wert_16
T_FILTER_V_VEH_SP
wert_16
V_LO_RED_SCHWENK_W_SP
wert_16
ABSCHWAECH_D_TAU_SP
wert_16
V_HI_RED_SCHWENK_W_SP
wert_16
MAX_SCHWENK_V_H_BEGR_SP
wert_16
ABSCHW_D_TAU_LO_SP
wert_16
MIN_SW_SCHWENK_V_HORIZ_SP
wert_16
ABSCHW_D_TAU_HI_SP
wert_16
V_LO_ABSCHW_D_TAU_SP
wert_16
V_HI_ABSCHW_D_TAU_SP
wert_16
AEND_V_SCHWENK_N_AUSSE_SP
wert_16
REDUZIERUNG_V_SCHWE_LO_SP
wert_16
V_LO_REDUZIER_V_SCHWEN_SP
wert_16
V_M_LO_REDUZIER_V_SCHW_SP
wert_16
RAMPE_EIN_BLK
wert_01
REDUZIERUNG_V_SCHWE_HI_SP
wert_16
V_M_HI_REDUZIER_V_SCHW_SP
wert_16
V_HI_REDUZIER_V_SCHWEN_SP
wert_16
RAMPE_AUS_BLK
wert_01
MAX_VERRINGERUNG_V_SCH_SP
wert_16
MIN_DELTA_MAX_VERR_SP
wert_16
MAX_DELTA_KEINE_VERR_SP
wert_16
RAMPE_EIN_KRV
wert_01
RAMPE_AUS_KRV
wert_01
RAMPE_EIN_RUE
wert_01
RAMPE_AUS_RUE
wert_01
V_S_LO_BLK
wert_01
MAX_HEIZZEIT
wert_01
HEIZ_ANF
wert_01
HEIZ_KNICK
wert_01
V_S_HI_BLK
wert_01
ABK_VERLAENG
wert_01
ABK_KNICK
wert_01
ABK_MIN_PROZ
wert_01
V_E_LO_BLK
wert_01
V_E_HI_BLK
wert_01
V_S_LO_KRV
wert_01
V_S_HI_KRV
wert_01
NACHL_RKW
wert_01
BLK_TIMER_STAND
wert_01
UNP_WELCOMELIGHT_CKM
aktiv
DEF_WELCOMELIGHT_CKM
aktiv
CC_MELD_LICHT_AN_WARNUNG
aktiv
TIMEOUT_SET_DTC
aktiv
DOPPELBLINKIMPULS_WARNBLK
nicht_aktiv
DOPPELBLINKIMPULS_CRASH
nicht_aktiv
FL_AUS_BEI_BIX_IN_S_FLC
nicht_aktiv
WL_FL
nicht_aktiv
WL_NSW
nicht_aktiv
WL_DAUER
wert_01
WL_MAX_DAUER
wert_01
WL_ZYKLEN
wert_01
WL_AL
nicht_aktiv
WL_KZL
soft_einschalten
WL_NSL
nicht_aktiv
PWM_VFB
wert_01
PWM_IB
wert_01
PWM_NSL_FKT_SL
wert_01
BREMSL_FKT_MIT_BFD
nicht_aktiv
BFD_1_MIT_BFD
wert_00
BFD_1_MIT_NSL
wert_00
ALC_ZUSTANDS_AUTOM
wert_02
ALC_ERR_NSW_ZUSCHALTEN
aktiv
ALC_SCHWENK_IM_STAND
aktiv
NEUE_FAHRT_KL_15_NACHL
wert_01
NEUE_FAHRT_OPTION
aktiv
MAX_SW_SCHWENK_W_AUSSEN
wert_18
ALC_ANHEBUNG_175_KM/H
wert_17
wert_02
ALC_VMAX_BESCHLEUNIGUNG
wert_17
ALC_ABSENKUNG_10_KM/H
wert_17
wert_02
ALC_VMIN_BESCHLEUNIGUNG
wert_17
ALC_ABWEICHUNG_TREND
wert_17
ALC_DAUER_DYN_NACHFUEHR
wert_17
ALC_MITTELUNGSINTERV_DYN
wert_17
ALC_VMAX_BREMSEN
wert_17
ALC_VMIN_BREMSEN
wert_17
ALC_SCHW_GRAD_BESCHLEUNIG
wert_17
ALC_ABTASTRATE_DYN
wert_17
ALC_MIN_STEIGUNG_VZ_WECHS
wert_17
ALC_MITTELUNGSINT_VZ_WECH
wert_17
ALC_MINDESTANZAHL_VZ_WECH
wert_17
ALC_ABTASTRATE_TREND
wert_17
ALC_MITTELUNGSINTERV_TREN
wert_17
ZUWACHS_TASTVERH_KL_58G
wert_03
ALC_DIFFERENZ_MSP_DYN_STA
wert_17
ALC_NACHLAUF_SCHLECHTWEG
wert_17
ALC_SAETT_TIMER_SCHLECHTW
aktiv
TASTVERH_BEL_WBL_MIN
wert_01
ZUWACHS_TASTVERH_WBL_BEL
wert_01
wert_01
ALC_SCHW_GRAD_BREMSEN
wert_17
FSP_ISP_SPERREN
wert_00
BFD2_BFD
nicht_aktiv
BFD2_NSL
nicht_aktiv
BEHOERDENFAHRZEUG
nicht_aktiv
BEHOERDE_FL_ASYNCHRON
nicht_aktiv
BFD2_BLINKEN
3_hz
BFD2_V_MIN
wert_01
BFD2_A_MIN
wert_01
SPLITDOOR_DAUER
wert_01
BFD2_T_ABS
wert_02
WBLG_A_ABS
wert_01
wert_02
WBLG_N
wert_01
WBLG_T_L_MIN
wert_01
WBLG_F
wert_01
WBLG_G_MIN
wert_01
WBLG_V_WBL
wert_01
PWM_FRA_H_FKT_BFD
wert_01
CC_MELDUNG_FRA_Z_L
wert_01
KALTUE_SML_M2_8_M2_32
nicht_aktiv
KALTUE_TFL_M1_1_M1_33
nicht_aktiv
WARMUE_SML_M2_8_M2_32
nicht_aktiv
ABBIEGELI_PL2_MIT_NSW
nicht_aktiv
LRE_VERBAUT
nicht_aktiv
NSL_AUS_BEI_FE_MODE
nicht_aktiv
NSL_AUS_BEI_FE_MODE_HECK
nicht_aktiv
PWM_FRA_Z_AN_SML
wert_03
IGR_SL_RELEVANT
aktiv
IGR_DRL_H_RELEVANT
nicht_aktiv
IGR_NSW_RELEVANT
aktiv
IGR_NSL_RELEVANT
aktiv
IGR_ABIEGELI_RELEVANT
nicht_aktiv
IGR_RFS_RELEVANT
aktiv
IGR_BFD_RELEVANT
nicht_aktiv
CC_MELDUNG_FRA_Z_R
wert_01
IGR_LH_RELEVANT
nicht_aktiv
IGR_WBL_RELEVANT
aktiv
IGR_TIPP_BLK_RELEVANT
nicht_aktiv
IGR_DAUER_BLK_RELEVANT
nicht_aktiv
IGR_IL_RELEVANT
aktiv
LED_LICHTFUNKTION
nicht_aktiv
PARKL_SL_1_GEDREHT
nicht_aktiv
FH_HALL_DIAG_ENABLE
nicht_aktiv
WL_SL_1_MIN_PWM
wert_01
BFD_1_ALGORITHMUS
aktiv
BFD_1_MIT_SL_1
wert_01
BFD_1_MIT_FRA_H
wert_01
BFD_1_MIT_BL_M
wert_01
WBLG_WBL_ENABLE
nicht_aktiv
BFD_1_MIT_BL
wert_01
BFD2_AKTIV
nicht_aktiv
BFD2_ESS_ENABLE
nicht_aktiv
BFD2_ESS_ANZEIGE
nicht_aktiv
BFD2_SL_1
nicht_aktiv
BFD2_BL_M
nicht_aktiv
BFD2_BL
nicht_aktiv
LWR_HEBEL
wert_01
wert_03
LWR_DIAG_PARAM
wert_01
RECHTS_LENKER
nicht_aktiv
ALC_EPSILON_DELTA_AV
wert_17
wert_02
ALC_EPSILON_DELTA_A
wert_17
FZG_RADSTAND
wert_18
NORM_LEUCHTWEITE
wert_18
wert_19
wert_20
C_METER_NACH_INNEN_HI
wert_18
wert_19
wert_20
LENK_UEBERSETZUNG
wert_24
wert_25
ABSCHWAECH_D_TAU
wert_16
wert_17
wert_18
wert_19
V_LO_REDUZIER_V_SCHWENK
wert_17
wert_18
wert_19
V_M_LO_REDUZIER_V_SCHWENK
wert_17
wert_18
wert_19
V_M_HI_REDUZIER_V_SCHWENK
wert_17
wert_18
wert_19
ALC_KENNLIN_LWR_SENSOR_VO
wert_21
wert_02
wert_23
ALC_LWR_VORZEICHEN
hinten_aktiv
ALC_ERR_BLK_FREQ
wert_02
SPLITDOOR_LIGHT_ACTIVE
nicht_aktiv
ALC_FAILSAVE
nicht_aktiv
LENK_UEBERSETZUNG_LO
wert_20
LENK_UEBERSETZUNG_LO_SP
wert_20
ALC_FAHRZEUG
nicht_aktiv
START_ABBL
wert_01
CC_MELD_SW_CI_NOT_AKTIV
aktiv
AUTO_LWR_ENABLE
aktiv
DYNAM_LWR_ENABLE
aktiv
LOAD_DUMP_DIMM_FL_PL3
nicht_aktiv
VERBAU_H_SENSOR_VORNE
links
SNU_TK_ABFRAGE_OHNE_PULSE
nicht_aktiv
ALWR_ENABLE
nicht_aktiv
ABBL_LZ_STAND
wert_01
ENDE_ABBL
wert_01
ABBL_LZ_RKW
wert_01
HYST_RKW
wert_01
VORH_HEIZZ
wert_01
C1_VERT_FA
wert_08
C1_VERT_BF
wert_01
C1_HORI_FA
wert_01
C1_HORI_BF
wert_01
C2_VERT_FA
wert_08
C2_VERT_BF
wert_01
C2_HORI_FA
wert_01
C2_HORI_BF
wert_01
V__VERT_FA
wert_01
V__VERT_BF
wert_01
V__HORI_FA
wert_01
V__HORI_BF
wert_01
E__VERT_FA
wert_08
E__VERT_BF
wert_01
E__HORI_FA
wert_01
E__HORI_BF
wert_01
E3_VERT_FA
wert_01
E3_VERT_BF
wert_01
E3_HORI_FA
wert_01
E3_HORI_BF
wert_01
V_LO_STADT
wert_01
V_HI_STADT
wert_01
V_MID_LANDSTR
wert_01
V_LO_AUTOB
wert_01
V_HI_AUTOB
wert_01
ZEIT_AUTOB
wert_01
V_NSW
wert_01
MAX_KRUEMM
wert_01
WEG_GERADE
wert_01
V_MIN_KRUEMM
wert_01
OFFSET_GESCHW
wert_02
NSW_AUTOBAHN
wert_02
REF_DEMO
wert_01
VERZ_REF_DEMO
wert_01
F_ALWR
wert_01
AG_M_ALWR
wert_01
GL_ALWR
wert_01
T_ALWR_AUS
wert_01
STRST_MAXDIFF_ALWR
wert_01
T_ALWR_NST
wert_01
T_ALWR_SW
wert_01
T_ALWR_AM
wert_01
T_ALWR_MKR
wert_01
W_ALWR_SW
wert_01
W_ALWR_EKR
wert_01
W_ALWR_MKR
wert_01
Z_ALWR_NST
wert_01
Z_ALWR_SW
wert_01
F_A_ALWR
wert_01
V_ALWR_AM
wert_01
V_ALWR_AUS
wert_01
V_ALWR_AN
wert_01
V_ALWR_BAB1
wert_01
V_ALWR_BAB2
wert_01
F_SWEG_ALWR
wert_01
R_SWEG_ALWR
wert_01
KALTUE_IB_M1_35
nicht_aktiv
KALTUE_BFD_M1_5_M1_37
nicht_aktiv
KALTUE_BLM_M1_40
nicht_aktiv
WARMUE_BFD_M1_5_M1_37
nicht_aktiv
WARMUE_TFL_M2_1_M2_33
nicht_aktiv
WARMUE_BLM_M1_40
nicht_aktiv
WARMUE_IB_M1_35
nicht_aktiv
WARMUE_KL_58G_M2_48
nicht_aktiv
VERBAU_ABBIEGEL_PL2_3R
nicht_aktiv
ABBIEGELI_AUS_BEI_FL_LH
nicht_aktiv
SIDEMARKER_US_MIT_FRA_V
nicht_aktiv
TIPP_BLK_ABBR_GEGENRICHT
aktiv
TIPP_BLK_ABBR_GLEICHRICHT
aktiv
DWA_UEBERFALL_ALARM_3R
mit_fl
HECKDECK_REVERS_ANZ_ZYKL
wert_01
HECKDECK_REVERS_DOPPELB
aktiv
STROMSPAR_WARNBLINKEN
aktiv
NSL_EIN_BEI_NSL_AHM_DEF
aktiv
LEUCHTDICHTE_EXPONENTIEL
nicht_aktiv
SM_FKT_ZUSATZBLINKER
nicht_aktiv
LED_BLINKER_HINTEN
nicht_aktiv
LED_BLINKER_VORNE
nicht_aktiv
MIN_TASTVERH_KL_58G
wert_01
wert_01
OPEN_LOAD_LED_BLINKER_H
wert_01
OPEN_LOAD_LED_BLINKER_V
wert_01
HEIMLEUCHTEN_FUNKSCHL
nicht_aktiv
LOAD_DUMP_SCHUTZ
aktiv
LOAD_DUMP_ABSCHALT_KL58G
aktiv
LOAD_DUMP_ABSCHALT_FL
nicht_aktiv
LOAD_DUMP_ABSCHALT_SL_1
nicht_aktiv
LOAD_DUMP_DIMM_WERT_FRA
wert_01
LOAD_DUMP_DIMM_WERT_KL58G
wert_01
LOAD_DUMP_DIMM_AL
aktiv
LOAD_DUMP_DIMM_BL
aktiv
LOAD_DUMP_DIMM_FRA_V
aktiv
LOAD_DUMP_DIMM_FRA_H
aktiv
IGR_BREMSLICHT_RELEVANT
nicht_aktiv
PWM_FL_FKT_DRL_3R
wert_01
PWM_NSW_FKT_PARKL
wert_03
PWM_FRA_V
wert_01
PWM_FL_NSW_FKT_ABBLIEGEL
wert_01
PWM_POL
wert_01
PWM_POL_BEI_AKTIVEN_FL
wert_01
PWM_NSW_FKT_TFL
wert_01
PWM_FRA_V_FKT_SIDEMARKER
wert_03
PWM_FRA_H
wert_02
PWM_BL_FKT_SL
wert_01
PWM_SL_2_FKT_BL
wert_03
PWM_BFD_3R
wert_01
PWM_BFD_ERSETZT_SL_1
wert_01
PWM_BL_M
wert_01
BFD_ERSETZT_SL_1
nicht_aktiv
BFD_ERSETZT_BL
nicht_aktiv
NSL_ERSETZT_SL_1
nicht_aktiv
NSL_ERSETZT_BL
nicht_aktiv
BL_ERSETZT_SL_1
nicht_aktiv
BL_ERSETZT_SL_2
nicht_aktiv
PARKL_FKT_MIT_POL
aktiv
PARKL_FKT_MIT_BL
nicht_aktiv
BL_SCHALTLOGIK_E92_93
nicht_aktiv
PARKL_FKT_MIT_SL_2
nicht_aktiv
PARKL_FKT_MIT_NSW
nicht_aktiv
SL_FKT_MIT_POL
aktiv
HECKKL_SL_LOGIK
nicht_aktiv
SL_FKT_MIT_NSW
nicht_aktiv
BREMSL_FKT_MIT_SL_1
aktiv
BREMSL_FKT_MIT_SL_2
nicht_aktiv
BREMSL_FKT_MIT_NSL
nicht_aktiv
DRL_TFL_MIT_SL_2
aktiv
DRL_TFL_MIT_KZL
aktiv
DRL_TFL_MIT_SML_3R
nicht_aktiv
DRL_TFL_MIT_BLK_V_GED
nicht_aktiv
DRL_TFL_MIT_NSW
nicht_aktiv
FH_LIN_BEDIENBLOCK
nicht_aktiv
FH_MAUT_AUF_FAT_ENABLE
aktiv
FH_MAUT_AUF_BFT_ENABLE
aktiv
FH_KURZHUB_DISABLE_FEMOD
nicht_aktiv
FH_WAIT_ST_WRG_ENB
aktiv
FH_TASTER_EINSTUFIG_L3
nicht_aktiv
FH_KURZHUBDELAY_ZU
wert_01
FH_TIME_WAIT_ST_WRG_ENB
wert_01
KURZSCHLUSS_CHECK_DISABLE
wert_01
wert_02
LWR_OFFSET_PLATTLAUF_L
wert_01
LWR_OFFSET_PLATTLAUF_R
wert_01
LWR_DIAG_COOL_TIME
wert_01
LWR_DIAG_HEAT_TIME
wert_01
ENABLE_GURTBRINGER_BF
nicht_aktiv
LWR_DIAG_PARAM_A
wert_01
GB_TRIGGER_KL_R
aktiv
GB_TRIGGER_KL_15
aktiv
GB_QUICKSTART
aktiv
GB_USE_SBE
nicht_aktiv
GB_POS_AUS
wert_01
GB_T_NOTLAUF
wert_01
GB_T_EINFAHREN
wert_01
GB_FAILSAFE
wert_01
GB_ENTPRELL_TRIGGER
wert_01
GB_ENTPRELL_CAN
wert_01
GB_NAD
wert_01
GB_DELTA_POS
wert_01
GB_ANZ_REVERSIEREN
wert_01
GB_T_REVERSIEREN
wert_01
ASP_EINKLAPPEN
nicht_aktiv
ASP_KOMFORT_EINKLAPP
nicht_aktiv
ASP_ELEKTROCHROM
nicht_aktiv
ASP_NO_SPIEGEL_LIN_START
nicht_aktiv
ASP_WEG_BORDSTEIN_AUTOM
wert_01
ASP_GESCHW_AUTO_AUSKLAPP
wert_01
BFD_1_MIT_SL_2
wert_00
BFD_GESPERRT_BEI_NSL
nicht_aktiv
BFD2_SL_2
nicht_aktiv
WL_FRA_V
nicht_aktiv
WL_FRA_H
nicht_aktiv
WL_FL_MIN_PWM
wert_01
ASP_MAX_GESCHW_EINKLAPPEN
wert_01
WL_BLK_H_MIN_PWM
wert_01
WL_AL_MIN_PWM
wert_01
WL_POL_MIN_PWM
wert_01
WL_NSW_MIN_PWM
wert_01
WL_BLK_V_MIN_PWM
wert_01
WL_SL_2_MIN_PWM
wert_01
WL_KZL_MIN_PWM
wert_01
WL_NSL_MIN_PWM
wert_01
WL_BL_MIN_PWM
wert_01
WL_BFD_MIN_PWM
wert_01
PWM_POL_BEI_AKTIVEN_AL
wert_01
ALC_PARAMETER_FAILSAVE_1
wert_01
ALC_NSW_NEU_ANF
aktiv
ALC_PARAMETER_FAILSAVE_2
wert_01
DUAL_SP_LAMPEN_ARRAY_1
wert_01
DUAL_SP_PARAMETER_2
wert_01
DUAL_SP_PARAMETER_3
wert_01
FSP_LAMPEN_MASK_FRM3
wert_01
ISP_MASKIERUNG_FRM3
wert_01
CC_MELDUNG_NSW_L
wert_01
CC_MELDUNG_NSW_R
wert_01
CC_MELDUNG_FRA_V_L
wert_01
CC_MELDUNG_FRA_V_R
wert_01
CC_MELDUNG_FRA_H_L
wert_01
CC_MELDUNG_FRA_H_R
wert_01
CC_MELDUNG_SML_L
wert_01
CC_MELDUNG_SML_R
wert_01
V_E_HI_KRV
wert_01
ENTGEGENGES_RKW
nicht_aktiv
CC_MELDUNG_SL_2_L
wert_01
CC_MELDUNG_SL_2_R
wert_01
V_E_LO_KRV
wert_01
FSP_MASKIERUNG_FRM3
wert_01
CC_MELDUNG_BFD_L
wert_01
CC_MELDUNG_BFD_R
wert_01
CC_MELDUNG_TFL_L
wert_01
CC_MELDUNG_TFL_R
wert_01
CC_MELDUNG_KZL_3R
wert_01
CC_MELDUNG_BL_M_1
wert_01
CC_MELDUNG_IB_3R
wert_01
CC_MELDUNG_KL_58G
wert_01
CC_MELD_PARKLICHT_EIN
wert_01
PWM_NSL_FKT_BFD
wert_01
WL_POL
soft_einschalten
WELCOME_LIGHT_ACTIVE
aktiv
ASP_HEIZUNG
nicht_aktiv
ASP_MEMORY
nicht_aktiv
ASP_BORDSTEIN_AUTOM
nicht_aktiv
EINLENKEN_RKW
nicht_aktiv
CS_GELB_ROT
wert_01
CS_ZW_WERTE
wert_01
CS_ZEIT_UML
wert_01
CS_MIN_PWM
wert_01
CS_RED_HELL
wert_01
CS_AUT_RED_HK
wert_01
FH_TUERAUF_STOP_MAUT_3R
aktiv
TYP_COLORSWITCH
dreifarbig
CS_QUITTIERUNGS_BLINK
aktiv
PARKL_FKT_MIT_SL_1
nicht_aktiv
PARKL_FKT_MIT_BFD
aktiv
SL_FKT_MIT_BFD
aktiv
PWM_BFD_FKT_SL
wert_02
WL_SL_1
nicht_aktiv
PWM_SL_1_FKT_SL_TFL
wert_02
PWM_SL_1_FKT_PARKL
wert_02
WL_BFD
hart_einschalten
DRL_TFL_MIT_BL
nicht_aktiv
DRL_TFL_MIT_SL_1
nicht_aktiv
DRL_TFL_MIT_BFD
aktiv
SL_FKT_MIT_SL_1
nicht_aktiv
WL_BL
nicht_aktiv
BL_SCHALTLOGIK_R60
nicht_aktiv
PWM_KZL_3R
wert_01
PWM_NSL
wert_02
PWM_RFS
wert_01
SNU_TYP
nicht_aktiv
PWM_BL_FKT_BL
wert_03
PWM_SL_1_FKT_BL_TFL
wert_01
ADAPTION_CAN_LWR_LWS
f_can
ALC_KLS_ENABLE
nicht_aktiv
AHL2_ENABLE
aktiv
ALC_IMMER_BEI_S_FLC
nicht_aktiv
SNU_NICHT_VERBAUT
nicht_aktiv
PWM_SL_2_FKT_SL
wert_02
SL_FKT_MIT_SL_2
aktiv
VERHALTEN_DRL_TFL_3R
drl_l
FH_US_REVERSE
aktiv
WL_SL_2
soft_einschalten
SIGNALBILD_SL
nicht_aktiv
FH_PANIKMODUS
aktiv
FH_PANIKMODUS_MIT_EKS
aktiv
FH_MAUT_ZU_FAT_ENABLE
aktiv
FH_EKS_AKTIV_L3
aktiv
FH_PANIKMODUS_MAN_L3
aktiv
FH_MAN_MIT_EKS
aktiv
FH_MAUT_ZU_BFT_ENABLE
aktiv
GB_CA_FAHRZEUG
nicht_aktiv
GB_V_MAX_KMH
wert_02
BFD_1_WERT_AX_EIN
wert_02
NO_BLK_RKW
nicht_aktiv
TIPP_BLK
nicht_aktiv
FL_ASSIST_CC_NOT_AKTIV
nicht_aktiv
BFD2_A_LOE
wert_02
WBLG_A_ANF
wert_02
ALC_ERR_BLK_AL_EIN
aktiv
LOAD_DUMP_ABSCHALT_KZL
aktiv
LOAD_DUMP_ABSCHALT_RFS
aktiv
LOAD_DUMP_ABSCHALT_NSW
aktiv
LOAD_DUMP_ABSCHALT_NSL
aktiv
LOAD_DUMP_ABSCHALT_SL_2
aktiv
FH_PARAMETER_2
r56
r55
r57
r60
r58
r59
FH_PARAMETER_3
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_4
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_5
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_6
r56
r55
r57
FH_PARAMETER_7
r56
r55
r57
FH_PARAMETER_8
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_9
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_10
r56
r55
r57
r60
r58
r59
r61
FH_PARAMETER_11
r56
r55
r57
r60
r58
r59
FH_PARAMETER_12
r56
r55
r57
r60
r58
r59
FH_PARAMETER_13
r56
r55
r57
r58
r59
FH_PARAMETER_14
r56
r55
r57
r58
r59
FH_PARAMETER_15
r56
FH_PARAMETER_0
r56
FH_PARAMETER_1
r56
OFFSET_ADC_SNU
wert_02
OFFSET_ADC_TK
wert_02
UNP_ZYKL_TIPP_BLK_CKM
wert_02
MIND_ANZ_ZYKL_TIPP_BLK
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_1
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_2
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_3
wert_02
DEF_ZYKL_TIPP_BLK_CKM
wert_02
FH_CC_MELDUNGEN
nicht_aktiv
ALC_DEF_LWR_SENSOR_HI
wert_19
wert_22
INVERT_COLORS
wert_01
ALC_KENNLIN_LWR_SENSOR_HI
wert_20
wert_02
wert_23
ALC_OFFSET_LWR
wert_24
wert_27
ALC_SCHW_PROP_ABWEICHUNG
wert_17
wert_20
ALC_LWR_NEIGUNG_KONSTANTE
wert_17
wert_22
ALC_HOEHENWEG
wert_17
wert_20
ALC_SCHW_TREND
wert_17
wert_20
LWR_SCHRITTE_STELLUNG_1
wert_01
SICHERHEITS_FZG
nicht_aktiv
RECHTSVERKEHR
aktiv
LINKSVERKEHR
nicht_aktiv
WINKEL_BLENDUNG
wert_02
GETRIEBE_HANDSCHALTER
nicht_aktiv
SCHALTER_R_GANG
nicht_aktiv
LWR_HYSTERESE_START
wert_02
LWR_VORBESTROMUNG
wert_02
XENON_LI
wert_02
ALC_DISABLE_AUSGL_NICK_GW
aktiv
ALC_AUSWERT_PROP_ABWEICH
aktiv
ALC_AUSWERT_GRADIENT
aktiv
AL_AUS_BEI_FL
nicht_aktiv
CC_MELDUNG_AL_L
wert_02
CC_MELDUNG_AL_R
wert_02
PWM_NSW_3R
wert_01
KALTUE_NSW_M2_37_M1_3_C33
aktiv
WARMUE_NSW_M2_37_M1_3_C33
aktiv
QUITT_BLK_ENTSICHERN
aktiv
QUITT_BLK_SICHERN
aktiv
DEF_QUITT_BLK_ENTSI_CKM
aktiv
DEF_QUITT_BLK_SICH_CKM
aktiv
UNP_QUITT_BLK_ENTSI_CKM
aktiv
UNP_QUITT_BLK_SICH_CKM
aktiv
QUITT_BLK_ZU_CHECK
aktiv
QUITT_BLK_ENTSICHERN_1
aktiv
QUITT_BLK_ENTSICHERN_2
aktiv
QUITT_BLK_ENTSICHERN_3
aktiv
QUITT_BLK_SICHERN_1
aktiv
QUITT_BLK_SICHERN_2
aktiv
QUITT_BLK_SICHERN_3
aktiv
QUITT_BLK_IGNORE_MOTORH
aktiv
TAGFAHRLICHT_ECE_0
aktiv
TAGFAHRLICHT_ECE_1
nicht_aktiv
TAGFAHRLICHT_ECE_2
nicht_aktiv
TAGFAHRLICHT_ECE_3
nicht_aktiv
DEF_TAGFAHRLICHT_ECE_CKM1
nicht_aktiv
UNP_TAGFAHRLICHT_ECE_CKM1
nicht_aktiv
AUTOM_LICHT_KONTROLLE
aktiv
SZL_LOW_VERBAUT
nicht_aktiv
COLORSWITCH_VERBAUT
aktiv
VIER_TUERER
nicht_aktiv
SL_FKT_MIT_BL
nicht_aktiv
LH_UND_NSW_NICHT_GLEICHZ
aktiv
FL_UND_NSW_NICHT_GLEICHZ
aktiv
PWM_FL_BEI_BIXENON
wert_02
NSL_EINSEITIG_VERBAUT_C34
linke_seite
LWR_ANSTEUERN
aktiv
LWR_FEHLER_BEWERTUNG
wert_01
ABSCHALTUNG_RFS
nicht_aktiv
LWR_ABS_MIN_STELLUNG_2
wert_02
LWR_SCHRITTE_STELLUNG_2
wert_02
AL_KL50_SCHUTZ
nicht_aktiv
SL_ABSCH_OHNE_ECE
aktiv
OPTIONEN_SL_ABSCH_TFL_FL
aktiv
FH_CONT_MAUT_NACH_KL50
aktiv
SL_PARKL_ABSCH_12H
aktiv
XENON_AL_VERBAUT
aktiv
BI_XENON_BEI_LH_3R
aktiv
HALOGEN_AL_VERBAUT
nicht_aktiv
KALTUE_BL_M2_43_M2_9
aktiv
WARMUE_BL_M2_43_M2_9
aktiv
BREMSL_FKT_MIT_BL
aktiv
CC_MELDUNG_BL_L
wert_03
CC_MELDUNG_BL_R
wert_03
KALTUE_POL_M2_50_M1_8
aktiv
KALTUE_FRA_V_M1_13_M2_40
aktiv
KALTUE_FRA_H_M2_45_M1_12
aktiv
KALTUE_SL_1_M1_14_M2_41
aktiv
KALTUE_KZL_M2_49
aktiv
WARMUE_AL_M1_6_M2_38
aktiv
WARMUE_POL_M2_50_M1_8
aktiv
WARMUE_FRA_V_M1_13_M2_40
aktiv
WARMUE_FRA_H_M2_45_M1_12
aktiv
WARMUE_SL_1_M1_14_M2_41
aktiv
WARMUE_KZL_M2_49
aktiv
CC_MELDUNG_POL_L
wert_01
CC_MELDUNG_POL_R
wert_01
CC_MELDUNG_SL_1_L
wert_03
CC_MELDUNG_SL_1_R
wert_03
FH_COUPETUER
aktiv
KALTUE_FL_M2_6_M1_04
nicht_aktiv
KALTUE_AL_M1_6_M2_38
nicht_aktiv
PWM_AL
wert_01
CC_MELDUNG_FL_L
wert_01
CC_MELDUNG_FL_R
wert_01
KALTUE_NSL_L_M2_51
nicht_aktiv
WARMUE_NSL_L_M2_51
nicht_aktiv
CC_MELDUNG_NSL_L_3R
wert_02
KALTUE_NSL_R_M1_10
nicht_aktiv
WARMUE_NSL_R_M1_10
nicht_aktiv
CC_MELDUNG_NSL_R_3R
wert_02
KALTUE_RFS_L_M2_47
aktiv
WARMUE_RFS_L_M2_47
aktiv
CC_MELDUNG_RFS_L
wert_01
KALTUE_RFS_R_M1_9
aktiv
WARMUE_RFS_R_M1_9
aktiv
CC_MELDUNG_RFS_R
wert_01
KALTUE_SL_2_M1_16_M1_18
aktiv
WARMUE_SL_2_M1_16_M1_18
aktiv
KALTUE_FRA_Z_M1_11_M2_44
nicht_aktiv
WARMUE_FRA_Z_M1_11_M2_44
nicht_aktiv
WARMUE_FL_M2_6_M1_4
nicht_aktiv
PWM_FL_N
wert_03
IGR_FAHR_AL_RELVANT
aktiv
IGR_TFL_RELEVANT
aktiv
IGR_FL_RELEVANT
aktiv
CS_FREQ
160hz_bei_hk300
DELAY_IL_WELC_SC
0sec
INNENLICHT_ABSENKEN
wert_09
TIME_COLOR_CIRCLE
3sec
aktiv
MIRROR_KOMM_DTCS
nicht_aktiv
LWR_STROM_HALT
wert_01
LWR_STROM_NORMAL
wert_06
LWR_STROM_RAMPE
wert_06
VIRTUAL_IBS_BEHAVIOR
shutdown_after_timer
VIRTUAL_IBS_ENABLE
nicht_aktiv
VIRTUAL_IBS_TIME
12h
VIRTUAL_IBS_TIMER_BEHAV
default
VIRTUAL_IBS_VOLTAGE_OFFS
0mv
Old Feb 12, 2014 | 07:10 AM
reducati's Avatar
reducati
my 2012 r 58 does it as well...never bothered me though...
Old Feb 13, 2014 | 10:17 AM
Kevdog's Avatar
Kevdog
aktiv
I think you may be on to something here. First, here are the differences in my trc file:
FZG_RADSTAND
wert_19
wert_20
FH_PANIKMODUS
nicht_aktiv
nicht_aktiv
nicht_aktiv
FH_EKS_AKTIV_L3
nicht_aktiv
nicht_aktiv
FH_MAN_MIT_EKS
nicht_aktiv
nicht_aktiv
wert_01
wert_01
wert_01
wert_01
wert_01
wert_23
INVERT_COLORS
wert_02
aktiv
SCHALTER_R_GANG
aktiv
nicht_aktiv
QUITT_BLK_SICHERN
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
QUITT_BLK_SICHERN_1
nicht_aktiv
QUITT_BLK_SICHERN_2
nicht_aktiv
QUITT_BLK_SICHERN_3
nicht_aktiv
nicht_aktiv
INNENLICHT_ABSENKEN
wert_06
TIME_COLOR_CIRCLE
5sec
nicht_aktiv
I also don't have the following three lines from your trc:
LWR_STROM_HALT
wert_01
LWR_STROM_NORMAL
wert_06
LWR_STROM_RAMPE
wert_06
My new guess on possible settings are
INVERT_COLORS
wert_02 yours wert_01
nicht_aktiv yours aktiv
In the next few days I will see if I can get mine to cycle. To tell you the truth, I haven't even noticed my accent lighting on when I unlock or open the doors. I do have them set to the lowest level though. I replaced all interior lights with LEDs and those are so bright, that that's all I see.
Attached Thumbnails Ambient Mood Lighting - Cycling through colors at door open.-frm-differences.jpg
Old Feb 13, 2014 | 11:12 AM
Angib's Avatar
Angib
This is all R56. Anyone want to see the interior light on the F56?
Attached Thumbnails Ambient Mood Lighting - Cycling through colors at door open.-disco-ball.jpg
Old Feb 13, 2014 | 11:23 AM
That's when they are in disco mode. 8/2010+
Old Feb 14, 2014 | 10:14 AM
Kevdog's Avatar
Kevdog
I can now confirm that setting WELCOME_SCENARIO_ACTIVE to nicht_aktiv in the FRM module makes it stop! I previously mentioned that I didn't notice the ambient lighting, and that is because the setting my car has turns the ambient lighting off until the START button is pressed.
When I set mine to aktiv, I locked, unlocked then opened my door. At that point it did one cycle through stopping at my original color. Sounds like your exact results. Then I set it back to nicht_aktiv because my interior LEDs make it unnecessary. Hope I helped.
Old Feb 14, 2014 | 10:24 AM
cerenkov's Avatar
cerenkov
Awesome, I will recode it this weekend.
Old Feb 24, 2014 | 08:26 AM
x2boxers
Awesome thanks! Now I just have to get into the whole programing / coding thing.
