R50/53 Need some help with wheel noise
Old Jan 27, 2014 | 09:24 AM
luisv528's Avatar
luisv528
I'm getting some annoying wheel noise from my front driver side wheel. Sounds like brakes are worn and they are screeching. I replaced brakes a few weeks back and that did not solve the problem. Brakes still looked good actually, but still replaced them anyway. Noise is still there. It is inconsistent as to when it does this. Some days its real bad other days I can not hear it. When it is screeching, if I tap the brake it will go away, sometimes turning the wheel quickly left or right can make sound get worse or go away for a few seconds. Anyone ever experience this. I'm suspecting its front wheel bearing but not 100 % sure. Any help would be greatly appreciated. I'm new to this forum, not sure if I am posting this in the rite spot.
Old Jan 27, 2014 | 07:01 PM
Da_Ghost's Avatar
Da_Ghost
Usually, a wheel bearing will make a noise at a certain speed, it won't just come and go. Did you checked the dust shield? If it's bent and touch the disc it can make a noise and most of the time, you will hear it when turning.
Old Jan 28, 2014 | 05:47 AM
luisv528's Avatar
luisv528
Thanks for the info.....will try the dust shield next chance I get
Old Jan 28, 2014 | 05:55 AM
PM'd you the list to check things out. Dust shield was on the list.
Spank
11
Apr 9, 2020 02:23 PM
woodstudio
Mar 15, 2020 08:28 AM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
TJANK
Aug 24, 2015 06:11 PM
