R50/53 Dropping subframe what else?
Old Jan 24, 2014 | 05:46 PM
Nicefeet's Avatar
Nicefeet
I have to drop the subframe on my R53.
I’m replacing the:
Inner ball joints
Outer ball joints
Control arm bushings (Powerflex)
Steering rack bush (Powerflex)
Swaybar bushings (Powerflex)
Both return and feed hoses for the power steering
The lower small bushing for the motor mount (Powerflex)
Is there anything else I should change while I’m in there?
The oil pan gasket, crank sensor oring, oil filter housing/cooler seals/o-rings were replaced this summer and it’s currently dry as a bone with the exception of my seepy weepy power steering lines.
I want to get any other adventures out of the way so I can have a full summer of motoring ahead of me.
Old Jan 25, 2014 | 03:58 PM
jnathan68's Avatar
jnathan68
Others may chime in but I think you covered it all. I just dropped mine recently...ball joints were a pain to get to "pop" loose but was able to get it done.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
navybsn
Oct 4, 2015 03:27 PM
buggyeye401
Oct 1, 2015 01:22 PM
aldito2
Sep 30, 2015 10:44 AM
buggyeye401
Sep 28, 2015 04:09 PM
