R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 Gauge pods for the Paceman?
Old Jan 23, 2014 | 09:16 PM
Eskimomice's Avatar
Eskimomice
Been looking online and google searches and have only found the high mount gauge pods for the paceman... Any other options available for the gauge pod mounts on the paceman that you guys have run across ?
Old Jan 23, 2014 | 10:01 PM
bmwr606's Avatar
bmwr606
http://www.outmotoring.com/dash-vent...uge-mount.html
Old Jan 25, 2014 | 06:47 AM
Eskimomice's Avatar
Eskimomice
I just discovered ScanGaugeII... I might go this route as it's a cost effective solution for getting some good data from the ECU. Also has a custom Mini firmware you can order with it for boost pressure/AF Ratio/etc...
any thoughts on it other than it looks ugly and square?
For those that have this already, where and how did you mount it?
Old Jan 25, 2014 | 07:13 AM
ASKtheteach's Avatar
ASKtheteach
It really doesn't look "ugly and square". It's fairly small and thin and easy to place anywhere. There is a Craven mount for it that attaches it to the tach. I have a Countryman, and with mine, I just attached it to the left corner of the dash using the velcro it came with. It's easy to read, provides lots of info, and is not intrusive at all.
Old Jan 25, 2014 | 07:24 AM
bmwr606's Avatar
bmwr606
http://www.cravenspeed.com/mini-flex...auge-ii-mount/
Old Jan 25, 2014 | 07:41 AM
Eskimomice's Avatar
Eskimomice
did you get yours with the Mini firmware? Was it additional charge?
might place the order when they get back to me about the additional firmware...
darn M-F work hours! TAKE MY MONEY ON THE WEEKEND TOO!
Old Jan 25, 2014 | 10:23 AM
bmwr606's Avatar
bmwr606
No extra charge for the custom mini gauges
Old Jan 25, 2014 | 01:46 PM
HorseWithNoName's Avatar
HorseWithNoName
I suggest taking a look at an obd2 Bluetooth setup for your phone or Garmin GPS.
I use Garmin Mechanic ecoRoute HD with my GPS and have everything I could possibly want from engine data to voice command navigation.
http://g.factoryoutletstore.com/Cate...earch_term=OBD
http://torque-bhp.com/software/torqu...obd2-adapters/
http://www.palmerperformance.com/pro...hone/index.php
http://www.plxdevices.com/product_info.php?id=GSSTWIFI
Last edited by HorseWithNoName; Jan 25, 2014 at 03:18 PM. Reason: added information
Old Jan 25, 2014 | 07:35 PM
Eskimomice's Avatar
Eskimomice
sweet! thanks!
I looked at the options and that looks pretty cool. I like the idea of it being wireless and bluetooth and I've seen the Kiwi devices before (on my S2000)... but it doesn't have the boost information that I'm looking for in the data for the PM... but that setup looks pretty flexible with the amount of different devices you can use... I use my phone for my GPS and music, so can't really use my phone for gauges =)
Old Jan 27, 2014 | 10:07 PM
Eskimomice's Avatar
Eskimomice
Scan Gauge II ordered with Mini specific gauge firmware!...
will post pics of install and location and so on when it gets in!
Old Feb 1, 2014 | 12:33 PM
Eskimomice's Avatar
Eskimomice
so got the ScanGauge in.... it's a little longer than I thought .... but a cm or so, so I can't fit it between the steering column and the drive side front vent....
brainstorming ideas....
M7Speed
Jul 10, 2018 09:26 AM
Doc Pain
Oct 28, 2015 07:09 PM
GVFlyer
R61 :: Paceman Talk
Oct 21, 2015 06:48 AM
Oct 1, 2015 12:13 PM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
