R50/53 Crank Sensor Problem
Old Jan 17, 2014 | 05:53 AM
jchamann's Avatar
jchamann
Hey Guys,
Just completed the ratchet strap method for replacing the crank sensor O Ring. Everything went well. Pretty simple procedure.
When I went to start the car, it wouldn't turn over. Hooked up a computer and it gave me a Crank sensor Code. I put the car back up on the lift and made sure the sensor was still plugged in, which it was.
Any ideas what's going on here? why am I getting this code?
Thanks!
Old Jan 17, 2014 | 05:57 AM
Helix13mini's Avatar
Helix13mini
Were you getting the same code before you replaced the sensor?
Old Jan 17, 2014 | 06:09 AM
jchamann's Avatar
jchamann
Nope nothing prior to replacing the Oring. I need to clarify I just replaced the Oring and not the sensor.
Old Jan 17, 2014 | 07:54 AM
Helix13mini
Pop the sensor back out and check that you don't have a bunch of metal sticking to the magnetic sensor. Also be sure that it seated correctly when you put the new crank sensor seal: it has to be completely (seated) flush with the engine block.
Kimolaoha
Jul 5, 2023 01:04 PM
Toolman
Jan 20, 2016 06:50 AM
alistaircookie
Oct 8, 2015 10:52 AM
keck.j
Aug 18, 2015 08:18 PM
massmini03
Aug 12, 2015 11:19 AM
