R56 Clicking steering wheel
Old Jan 16, 2014 | 11:19 AM
capt fred's Avatar
capt fred
My 2011 S has just started making a clicking sound when I move the steering wheel. It makes a single click when the wheel is moved off center to eiither side. It is definitely coming from inside the steering wheel hub. I tried moving the wheel in and out with tilt/telescope, but that makes no difference. I changed the steering wheel to the JCW wheel about two years ago and every thing has been fine until now. Anybody ever have this problem? Any ideas?
Old Jan 16, 2014 | 11:28 AM
MikewithaMini's Avatar
MikewithaMini
Check where the column goes through the firewall behind the pedals. There is a joint there with a single bolt closest to the floor - 13mm. See if it's tight.
Old Jan 17, 2014 | 12:27 PM
capt fred's Avatar
capt fred
Thanks for your reply. I did check that bolt as you suggested; it was tight, but I appreciate your reply. I guess I will have to take the wheel off and see what I can see.
Old Jan 17, 2014 | 01:19 PM
Spridget's Avatar
Spridget
Does the MINI have some sort of slider for a horn contact? Those can get noisy, and can usually be fixed with a bit of dielectric grease.
Spridget
Old Jan 17, 2014 | 04:39 PM
MikewithaMini
Well it was a shot in the dark without hearing it. Let us know what you learn!
Old Aug 18, 2014 | 02:49 PM
komet155's Avatar
komet155
Did you figure out the clicking problem?
I just swapped in my new JCW wheel and was hearing a click every time I turned left. I then swapped back in the old wheel and the clicking went away.
Anyone know why that would happen?
theblackfalcon
Oct 11, 2015 09:49 AM
nomar116
Aug 12, 2015 05:24 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
nismo4life
Aug 5, 2015 08:31 AM
