Drivetrain Throw Out Bearing Killed Trans (Getrag)
Old Jan 13, 2014 | 03:14 PM
stxmini's Avatar
stxmini
Hello!
Just wanted to put this out there for you guys. I am going to try to get this welded if not looking for a new transmission. The only thing I noticed was a small oil leak. Transmission shifted fine with no problems.
Already ordered Valeo Clutch and Flywheel kit since the car is approaching 100k mi
Wish me luck!
Attached Thumbnails Throw Out Bearing Killed Trans (Getrag)-photo-4-1-.jpg   Throw Out Bearing Killed Trans (Getrag)-photo-1.jpg   Throw Out Bearing Killed Trans (Getrag)-photo-3.jpg
Old Jan 14, 2014 | 03:07 AM
cmt52663's Avatar
cmt52663
OUCH OUCH OUCH! My sympathies.
Kind regards,
Charlie
Old Jan 14, 2014 | 02:33 PM
stxmini's Avatar
stxmini
thanks! cannot believe this...
the bell housing is at the machine shop as we speak and will post pics once i get it back
Old Jan 14, 2014 | 02:35 PM
stxmini's Avatar
stxmini
forgot to ask...
anyone else gone through this experience? or, am i the lucky 1 in a million this happens to?
Old Jan 14, 2014 | 02:37 PM
GreekDrifter91's Avatar
GreekDrifter91
no it has happend to others... most get the holes welded shut other get new trans and other jsut get rid of there cars.... silly people
Old Jan 14, 2014 | 09:27 PM
soccerbummer1104's Avatar
soccerbummer1104
yea I'd weld that shut in a heart beat.
Pretty easy really.
Only thing "special" you need outside of a welder is a oven.
To get a good and strong aluminum weld you want all of the oil gone.
Cast is porous.
Best way is to put it in an oven and let it bake out slowly as well as cleaning it.
but crap, If that happened to me, I'd have it fixed in an hour or two :P
Best of luck, should be easily fixed.
Old Jan 15, 2014 | 03:16 AM
bavmotors's Avatar
bavmotors
This frightens me every time I hear my throw out bearing rattle at idle. Hope it works out for you, save the minis!
Old Jan 15, 2014 | 04:46 AM
tummi_gummi's Avatar
tummi_gummi
Scary! My throw out bearig knocks sometimes when I'm off the clutch and idling. New clutch and LSD are on my to do list!
Old Jan 15, 2014 | 08:58 AM
stxmini's Avatar
stxmini
Pretty easy really.
Cast is porous.
That is exactly what my machine shop said a couple of hours worth of work. The problem is getting the trans out. That is definitely not an hour or two worth of work. I am crossing my fingers they are able to get a good weld and the trans or lsd was not damaged. I did not run the trans dry but it was certainly low.
Witsticka
16
Jun 23, 2021 07:34 AM
QuickCooper
Dec 29, 2016 06:46 PM
AoxoMoxoA
Sep 13, 2015 03:17 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 3, 2015 02:06 PM
