JCW CEL: NM Eng. Hi-Flow Induction Kit Check Engine Light
I just bought my wife and I JCW's. I came for a 2009 135i and she from a 2004 Honda Civic.
Hers happens to have the NM Eng. Hi-Flow Induction Kit on it Here.
When we first looked at the car and took it for a test drive, everything was fine. We did all the paper work and as we started the car to go home, the check engine light came on. I left the car with the dealership to get it fixed. The brought the car to me 2 days later. The light was off when the driver drove to my house, but as soon as we started it up, CEL.
Right now the dealership is going to buy me a stock intake and install it this coming monday. I am familiar with after market parts and CEL fixes, but I don't know what the fix is for this car as we just got it 2 days ago. Anyone have any advice? I searched the forum, but found nothing. TIA.
http://locktheweb.com/misc/valve3.jpg Check that pic out. (That is an n18 engine) It has a heated PCV on the front -
The valve runs from the cam cover down to the air inlet just before the turbo.
I could be wrong.. but I think the JCW used the the N14 engine for a longer production run (into 2012?). Someone may have added a PCV block off - the N14 is known for carbon buildup on the valves. Someone may have bypassed it in order to try to slow the carbon buildup (however, its not the correct way to block it off).
http://farm1.static.flickr.com/128/3...a74b549bc2.jpg that is the N14. It has another style cam cover.
To get this sorted out, which one do you have?
Here is the NM on the N14 - http://a248.e.akamai.net/origin-cdn....g%3F1380726323
Here is the NM on the N18 - http://www.nm-eng.com/prod_images/xl...58857_img2.jpg
However, neither of them should have *anything* to do with the PCV setup on *either* engine setup.
(note the blue hose is part of the bigger intake - that still has nothing to do with a PCV fault..)
So the dealer took the NM intake out of the 2013 JCW and installed the stock box. No CEL at this point.
I did install the NM intake in the 2012 JCW and worked great! I did need to order a new metal mounting bracket as the 2013 used a slight different one, but for now its working fine with some zip ties
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
