R56 PCV Delete + OCC - my intake manifold looks... different...
Old Jan 5, 2014 | 05:29 PM
meeek's Avatar
meeek
Hello all. I was looking at possibly undertaking a PCV delete + OCC (still looking at all the relevant threads for- and against-) when it warms up.
However, in all the threads I looked at with pictures showing the PCV hose and delete points, I noticed that the intake manifolds pictured do not look like mine. I am attaching some pics of what mine looks like (I ran outside in sub-zero temps to get the pics!)
In short, the PCV hoses are much different. I had to have the entire manifold replaced when one of these little rubber hoses got weak and collapsed. Under warranty... but still...
Thoughts on why my intake is different than most that I have seen? And how can I do the PCV delete on this one? (or can I even do it?)
Thanks,
-Michael
Old Jan 5, 2014 | 05:33 PM
meeek's Avatar
meeek
OK so images did not attach the first time...
Attached Thumbnails PCV Delete + OCC - my intake manifold looks... different...-img_6896.jpg   PCV Delete + OCC - my intake manifold looks... different...-img_6895.jpg
Old Jan 5, 2014 | 07:12 PM
Tylerlanger1's Avatar
Tylerlanger1
You have the "cold weather manifold installed on your vehicle". On a vehicle with a normal intake the pcv is routed into the intake behind the throttle. In freezing temps the excess moisture freezes the throttle and you have starting and running issues. Luckily for you u have the updates intake which injects the pcv gas into the manifold right before the cylinder and no more freezing throttle issues.
Old Jan 6, 2014 | 05:48 AM
meeek's Avatar
meeek
Thanks Tylerlanger. Once you mentioned the 'cold weather manifold', I looked up some more threads and did find it. I still have not seen anyone do a PCV delete on the manifold side though.
Old Jan 6, 2014 | 06:48 AM
Some guys talked about it here. But were using it for a possible carbon cleaning mod.
https://www.northamericanmotoring.co...seafoam-3.html
Intake Manifold Part # 11614584240
http://www.ecstuning.com/Search/SiteSearch/11614584240/
But used for a TSB on iced throttles. Cold climate.
https://www.northamericanmotoring.co...ilable-15.html
1161551 Replacing intake manifold 44WMINI 0.13
1 11-61-4-584-240 intake manifold: 116010
57301 Iced Throttle 1161551 1.30 0.13 found moisture down by throttle.
Old Feb 28, 2023 | 01:03 PM
Hello,
Just an update, we finally have this hard to find part as the Genuine MINI part has been NLA since 2018.
https://www.ecstuning.com/b-bremmen-...614584240~brp/
Old Aug 3, 2023 | 12:56 PM
Just landed and in stock now for the part above.
DefoMini08
Feb 15, 2022 10:55 PM
cumang0
Cooper (non S)
Feb 22, 2019 04:39 AM
user 7398330
Sep 24, 2013 08:05 PM
ScorpionSkins.com
Apr 9, 2013 11:43 AM
