2011 R56 Whirling noise after engine shutoff
Old Dec 25, 2013 | 08:12 PM
theunclesam's Avatar
theunclesam
Hello everyone,
Lately I've noticed a strange whirling noise after I shut down my MINI. I'm used to hearing the oil pump (I think that's what ran to cool the turbo) and remember it constant until it quit. Today, however, I noticed this same noise, but it was intermittent, and didn't sound normal (not to me anyways).
Luckily, I was able to catch it on video. You'll have to turn up your volume just a bit to hear it (promise no scare surprise )
Any ideas if that's normal? If not, what do you guys think is going on?
EDIT: Also, I've noticed a slight whirling noise when engine RPM is around ~2k or so. Related?
Old Dec 26, 2013 | 08:38 AM
Summons's Avatar
Summons
When you shut your engine off, there is an auxiliary water pump that runs to help cool the turbo down. In some ways it sounds like that pump is running, but poorly - as though the bearing were failing, and the motor is now struggling to turn the pump.
The cooling fan for my after market amplifier makes a similar sound until it warms up...
Do you hear the coolant pump operate at all?
E.
Old Dec 26, 2013 | 11:52 AM
theunclesam
E.
My recording was right after engine shut down. I'm just wondering if it's normal, or if there's a problem as you say.
Wish someone could make a recording of there's after a hot engine shutdown.
Old Dec 26, 2013 | 12:23 PM
danjreed's Avatar
danjreed
That stuttering did not sound normal.
Old Dec 26, 2013 | 01:40 PM
theunclesam
Sheeeet! Do you think it's the aux water pump going then?
Old Dec 26, 2013 | 06:11 PM
danjreed's Avatar
danjreed
IT sounds like its turning on and off.. that or its a cooling fan stuck.. I'm not sure.. you could feel around (safely) for the aux pump to see if its vibrating as it does it..
Old Dec 28, 2013 | 03:38 PM
theunclesam
So which side of the car should the aux water pump be on? I thought it was the passenger side, but after hearing the noise today, it's clearly coming from the driver's side. Is there something else?
Old Jan 1, 2014 | 04:13 PM
rob99281's Avatar
rob99281
you had your camera pointed at a tube that goes to the turbo. take a flashlight and look directly under it and you will see a little black thing about 2x2, surrounded by wires. that is the aux pump for coolant to the turbo. it will run after vehicle shut off. if you have doubts, reach down and grab it, it should be vibrating along with the noise you hear. DO NOT BURN YOURSELF ON A HOT TURBO. if you have doubts, bring it in , its under warranty we will look at it no prob. feel free to ask a tech.
Old Jan 1, 2014 | 08:19 PM
theunclesam
Should probably mention my car has 51k miles on it. No more warranty for me.
Old Jan 3, 2014 | 08:29 PM
rob99281's Avatar
rob99281
Im sure its fine unless the noise is super loud, it sounds like its just running. they sell warranty extensions worth every penny
TBRoye
Feb 14, 2021 05:16 AM
Zettinger
Aug 25, 2015 04:04 PM
damncajun
Aug 17, 2015 08:25 PM
Aug 14, 2015 01:45 PM
