help will 17x9 fit ?
Old Dec 25, 2013 | 07:20 AM
Dauam7's Avatar
Dauam7
well I have a 17x9 35 enkei rpf1 that I used for a summer on my old subaru tire size is 235/40r17
I love the rims and honestly wouldn't want to sell it cause I know i won't get what they are worth
so my question is what size adaptors do i need to rum? (smallest i found was 18mm)
And will i be able to tuck the rims in?
i plan on doing H&R springs, i have a 2013 cooper s
Old Dec 25, 2013 | 12:47 PM
v10climber's Avatar
v10climber
Almost guaranteed they won't fit. Biggest I've seen on a mini was 17x8
Sent from my Nexus 10 using NAMotoring
Old Dec 26, 2013 | 11:52 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Enkei RPF1 in 17x9" only come in 5x114.3 bolt pattern and MINIs are 4x100 so they won't work.
For that wheel only 17x7" in the MINI bolt pattern is available.
http://www.enkei.com/rpf1.shtml#
http://www.enkei.com/size_chart/RPF1.pdf
If you did find a 17x9" rim to fit the 235/40-17 tire would work but you'd need a lot of negative camber to avoid rubbing due to the wide rim and wide tire. The more common approach is to use a wide wheel and a very narrow stretched tire like 205/40-17.
see also-
https://www.northamericanmotoring.co...pired-r53.html
Old Dec 27, 2013 | 04:45 AM
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
On my current set up I have 1/4" clearance to the wheel wells. Are you sure of this wheel ? What suspension do you have also ? You may have to get real low pros for tires if you are dropped....see my pics...LOW!!!!
Old Dec 27, 2013 | 06:41 AM
george_talbot's Avatar
george_talbot
17x9.75" has been fitted to the rear of a mini before. The issue is once you fit an adaptor with this wheel the offset will be crazy as the adapter will act like a massive spacer. You would be better off doing a hub re-drill. However, this sounds like more hassle than its worth. Loads of negative camber will be needed and your arches rolled and trimmed.
Old Dec 27, 2013 | 11:33 AM
Dauam7's Avatar
Dauam7
yeah its looking like ill have to sell this rims huh.
i was plan on going with h&r springs. with stock everything else
i deff did not want to redrill the hubs cause i dont want to spend that much just for rims honestly
Old Dec 27, 2013 | 01:54 PM
Dr. Spade's Avatar
Dr. Spade
Yea with the adapters necessary, it wouldn't fit.
Last edited by -=gRaY rAvEn=-; Dec 31, 2013 at 01:46 PM. Reason: Respect for other members
Old Jan 4, 2014 | 05:27 PM
Dauam7's Avatar
Dauam7
yeah i been looking at some bbs rs replicas, they have esm and str they seem like the same but i cant find weight info or much on it any comments and recommendations ?
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
