R50/53 oil drain plug damage!
Old Dec 23, 2013 | 04:06 PM
Saltysalt's Avatar
Saltysalt
This is not what i wanted to happen on the eve to Christmas eve, i was giving my baby an oil change and as i was getting the drain plug out nearly two threads of the helicoil in the pan came out, when reinstalling the plug it keeps threading, but i can have it slightly snug.
im not going to drive it till i have it fixed.... it sucks
just had to get home from the shop
i was wondering if anyone has had this issue?
i dont know if i should drill it out and retap it or to get a new oil pan
i have an aftermarket warranty and ill see if that is covered, im sure it is
Old Dec 23, 2013 | 07:44 PM
v10climber's Avatar
v10climber
Was it actually a helicoil brand insert or was it a timesert? If the helicoil was put in without any loctite between the helicoil and the oil pan the helicoils can back out with the bolts. Either thread the insert back in or pop a new insert in there. Its probably fine.
Sent from my Nexus 10 using NAMotoring
Old Dec 23, 2013 | 07:46 PM
Saltysalt's Avatar
Saltysalt
what ever it was it didnt back out with the bolt, it broke off, wish i took a pic of it
Old Dec 24, 2013 | 10:08 AM
noodlesandsam's Avatar
noodlesandsam
Bummer. Helicoils are springs. Timecerts are a solid single piece. Less chance of breaking like this. Good luck
Old Dec 24, 2013 | 10:28 AM
MINIdave's Avatar
MINIdave
Why do you think you have a helicoil in there, did you put one in at some point?
Was the material that came out aluminum or SS? That would help you know what was going on.
Unless you have had a helicoil put in in the past, I think you've stripped the threads in the aluminum pan and that's what came out with the plug. So, now you need to put a helicoil or timesert in to repair it.
Old Dec 24, 2013 | 06:57 PM
Capt_bj's Avatar
Capt_bj
put in a Fumoto so you never have to remove the bung again!
Old Dec 30, 2013 | 07:54 AM
Saltysalt's Avatar
Saltysalt
it was the aluminum material from the pan
as for the fumoto valve, really cool idea, but i would still need to either retap or get a new pan,
ima call my warranty people today and see if they will just do a new pan
Old Dec 30, 2013 | 09:22 AM
Eric_Rowland's Avatar
Eric_Rowland
Do you have the OEM oil temp gauge? I do, and I experienced the same problem. Rather than fix it, I just used an aftermarket drain plug that engaged more than three threads . Guess one day I'll do the proper repair.
Old Dec 30, 2013 | 12:18 PM
Saltysalt's Avatar
Saltysalt
No, but i have the ultra guage, before i leave work today, ima make sure my oil pressure is being shown haha
Old Dec 30, 2013 | 12:26 PM
ZippyNH's Avatar
ZippyNH
Suggestion on a gen1...
Either use an aftermarket drain plug...they sell them with course threads...slightly oversized...it will cut new ones...then replace repair the pan when you do tge next oilpan gasket...
You might get a fumoto drain plug in there... Get it tight...might try to add some sealant just to be sure...then reuse it on the fixed pan...do it right..be lucky, might last forever!!
Old Dec 30, 2013 | 05:13 PM
ashchuckton's Avatar
ashchuckton
I'm not a fan of those drain valves, but in this instance I'd re-thread or use a timecert put the valve in & call it good.
Old Dec 30, 2013 | 08:39 PM
Eric_Rowland
How would the ultragauge show oil pressure? No OBDII feed for that, AFAIK.
Old Dec 31, 2013 | 05:08 AM
Saltysalt's Avatar
Saltysalt
ultraguage doesnt show, sad face
woodstudio
Mar 15, 2020 08:28 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
Getrieben
Aug 15, 2015 09:09 PM
