R56 2007 S reliability
Old Dec 22, 2013 | 06:40 AM
hangout's Avatar
hangout
2007 S reliability
Hi, I always want to get a MINI S,
now I found one 2007 S, with 25k miles, Navi, auto. $15000.
I will drive the car to work everyday 100 miles.
is it a good choice? I heard that the 2007 S has some issues while the mileage build up. If I'm going to buy the car, where should I look at it?
If I want headaches free, besides 2007 S,, what else mini I should search for? the regular hardtop/other years?
Old Dec 22, 2013 | 08:53 AM
Husam Hammadi's Avatar
Husam Hammadi
If i were you, i would never buy a MINI for such high mileage needs. From what i hear on this forum, all R56's are unreliable so if you must get a Mini, get a low mileage R53....
Old Dec 22, 2013 | 12:38 PM
danjreed's Avatar
danjreed
Originally Posted by Husam Hammadi
If i were you, i would never buy a MINI for such high mileage. From what i hear on this forum, all R56's are unreliable so if you must get a Mini, get a low mileage R53....
Yea, 25K miles, that thing is due for the junk heap?
While, yes, 2007 was the first year, and has problems..;
T-stat housing/T-stat. (leak)
Turbo Oil Lines (leak)
Timing Chain Guides/Tensioner. (Covered under current recall)
Vacuum Pump Failure for brakes.
Oil Leaks.
Clutch Issues.
Overly long oil change intervals.
Carbon Buildup.
If you buy it.. knowing ahead of those issues.. we are well covered. Lots of OTHER stuff does not break. Just have a good look and listen to it. Check records, car fax etc.. its like any other car.. all cars have issues. Its a turbo, n14 DI car.
They stopped making the R53 in 2006. Good luck finding one with "low miles" unless the person never drove it.
Old Dec 22, 2013 | 01:03 PM
hangout's Avatar
hangout
25k miles..
25000 is really low mileage already, isn't it?
Old Dec 22, 2013 | 01:12 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by hangout
Hi, I always want to get a MINI S, now I found one 2007 S, with 25k miles, Navi, auto. $15000. I will drive the car to work everyday 100 miles. is it a good choice? I heard that the 2007 S has some issues while the mileage build up. If I'm going to buy the car, where should I look at it? If I want headaches free, besides 2007 S,, what else mini I should search for? the regular hardtop/other years? Thanks
Stay away from the 07-08 second gens. I'd look for an 09+. Or 05-06 first gens. Trust me, you won't regret it.
Old Dec 22, 2013 | 01:22 PM
oldsbear's Avatar
oldsbear
The "Justa Cooper" (without turbo) has been more reliable than the S. For that reason, if you want a MINI, I'd recommend a "Justa." A Honda or Toyota with similar mileage would likely be a more reliable 100-mile-per-day commuter, but not nearly so much fun to drive.
The turbo engine was redesigned for 2011, so if you want an S, you might search for a 2011 - 2013 hardtop. My 2011 MCSm has been great; however, I bought it new and have only about 22,000 miles on it, changing oil twice a year.
If you give the VIN to a MINI dealership, they can check the service record of the car, and let you know if common major warranty fixes -- like the timing chain tensioner and turbo cooler -- have been done, and if oil changes were done more frequently than the ridiculous MINI-recommended ones.
Old Dec 22, 2013 | 02:52 PM
Capt_bj's Avatar
Capt_bj
I first read this as most of you did - that 25k was high miles for a 2007
BUT on re-read
I think the warning was about buying a 2007 and putting on 100+ miles a day . . . .
I recently sold my 7 with 50,000 miles and that was considered LOW . . . less that 10,000 a year . . .
Old Dec 22, 2013 | 03:05 PM
elsenordave's Avatar
elsenordave
I bought my 07 MCS with 76k miles. I drive a 100 miles a day. I averaged 75days between service on my last rig and expect about the same here. IMHO cars are meant to be driven...so I'll drive it.
Old Dec 22, 2013 | 03:12 PM
flashlightface's Avatar
flashlightface
danjreed-
What about the plastic water pump? I've got all these things on my "to do list". I have 23k- extremely high mileage-
Old Dec 22, 2013 | 08:28 PM
xsmini's Avatar
xsmini
Haha! Thats a good one. There is a lady near me that has an 07 with over 400,000 miles on it. Has been back to the dealer once for a turbo replacement. She drives close to 270 miles a day. Hers makes my 03 with over 320,000 miles look like a sissy.
Treat them right, they'll last.
Nik
Old Dec 22, 2013 | 09:05 PM
RobMuntean's Avatar
RobMuntean
Originally Posted by xsmini
Haha! Thats a good one. There is a lady near me that has an 07 with over 400,000 miles on it. Has been back to the dealer once for a turbo replacement. She drives close to 270 miles a day. Hers makes my 03 with over 320,000 miles look like a sissy. Treat them right, they'll last. Nik
Maintenance and luck both play into the car treating you right, especially MINIs.
Old Dec 24, 2013 | 11:06 AM
mbwicz's Avatar
mbwicz
A few comments, similar to the others:
Make sure that maintenance has been done before buying it: Water pump/thermostat leaks, timing chain/tensioner, oil leaks at oil cooler and turbo oil lines, battery replacement is probably due also. I would also have the car checked for carbon cleaning.
Many of the mechanical issues are due to long oil change intervals. If this car had yearly oil changes, then I would not be too scared.
$15k sounds pretty steep, even if the car is beautiful. I would think $11k-12k would be more in line for a 6 year old car.
Definately take the VIN to the dealer to check maintenance history before making a decision. If you have to pay to have work done on the car, it is easy to spend $$$$ on some of these fixes.
Have fun,
Mike
Old Dec 30, 2013 | 09:33 PM
Chuck W.'s Avatar
Chuck W.
My wife has 25,000 miles on her Mini S. Oil changes every 5,000 miles. Besides a few recalls zero problems.
Old Dec 30, 2013 | 10:36 PM
vetsvette's Avatar
vetsvette
Moderator
Just took mine in for the timing chain recall. Change the oil every 5K. I like mine just fine.
Old Dec 30, 2013 | 10:50 PM
onefish2's Avatar
onefish2
2009 JCW here. 37000 miles. Oil changed every 5000 miles. Clutch replaced under warranty at 28000 miles. That was a JCW clutch issue. Just had the timing chain and tensioner replaced under warranty. Those were the 2 biggest issues.
Many people report that these cars burn oil. In 5 years, I believe that I have added 2 quarts of oil independent of an oil change.
I am on my 3rd windshield. In my 25 years of driving I have never had to replace a windshield on a car. Let alone twice. This was covered under my insurance so a zero dollar repair to me.
Lots of issues with the sunroof rattling. Just had that fixed again. This time I split it 3 ways. MINI paid 1/3. Dealer paid 1/3. And I paid 1/3. Out of pocket $515. And I think I got away cheap.
I would NEVER buy ANY used European cars. They are expensive to repair and the parts to repair them are expensive.
And then you have the NAM peer pressure with mods. That is a whole other story.
If I needed a 100 mile a day commuter car. I would buy a new Hyundai, Kia, Toyota or Honda.
Old Dec 31, 2013 | 07:50 AM
dmyer's Avatar
dmyer
I have a 2007 MCS with 65K on it. It has been well maintained with bi-yearly oil changes and all other recomeneded mantenance. Non routine maintenance problems I have encountered:
  • Timing Chain - Warranty
  • After Run Cooling pump - recall
  • High Pressure Fuel Pump - Warranty
  • Turbo Oil Lines Leak - Replaced myself - $150
  • Valve Cover PCV/Turbo Failed/Intercooler/intake system cleaning $3K
  • Clutch - $2.5K
  • Thermostat Housing - $300
  • Water Pump - $350
The vast majority of my expenses have been in the last two years.... I autocross the car about 15 times a year so that may increase the wear and tear. IMO it is what it is - do not kid yourself that just because it is low miles, that you will not have issues.... As others mentioned... for a long distance commuter car, far better, less costly, choices are available.... if you intend to run the Mini hard in competition and are willing to pay for maintenance.... then maybe the joy of driving will exceed the pain of your maintenance cost.
Old Dec 31, 2013 | 09:07 AM
blunderbird's Avatar
blunderbird
i bought my 07 MCS used last year with 48k on the clock, its now got 67k on the clock. in the last 6 months i have only been telecommuting, so that give you an idea of how quickly the miles accumulated. and those miles were blasting across LA twice a week, not exactly nice country 2-lanes..
i can see where if you're not handy, these cars can be expensive to keep running (really, no worse than anything else though). but this thing has been very reliable for a used car, and compared to the truck i WAS driving, the cheaper insurance and fuel expense has easily offset the maintenance.
but seriously?
sun-roof rattle = fixed in 20 minutes with a T-30 torx and a credit card
thermostat stuck full open = $200 total in parts, half a day of my time, and a good opportunity to change the coolant (had just bought the car, so of course i changed all the fluids).
1 lower ball joint started clunking, first time i've paid a shop to work on it. so i had both control arms, ball joints, and both bushings replaced, as well as the turbo oil cooler feed hose replaced, and an alignment done for $1600 out the door. i'm perfectly happy with ball joints lasting 65k on so-cal roads, i sell jeep and dodge parts, those guys are happy when they get 30k miles out of a set of ball joints.
other than that stuff, just basic oil and filter changes, and i'm due for plugs which should cure the slight detonation i get when its cold. if you drive it like a performance car and change the oil every 3-5k mi you shouldn't be getting carbon buildup.
would i drive one of these cars 100 mi every day? i dunno, i'm planning on keeping mine for a long time. if you're gonna make a commute like that, you probably should just buy a kia and throw it away after 5 years, since in 5 years no one will want one. your chances of getting creamed by some idiot teenager speeding while texting are pretty high these days, may as well sacrifice a Kia over a Cooper S...
Old Dec 31, 2013 | 09:42 AM
Astrobl4ck's Avatar
Astrobl4ck
I just bought a 2007 r56 S this week and I it's at the dealer because it has a coolant leak
Old Dec 31, 2013 | 09:53 AM
abonn
64k miles & almost no issues
My only repairs were 20km timing chain tensioner (warranty), 60km clutch ($2,000), & footwell module (FWM, also known as LKM or LCM - $600). No other failures.
I self-perform maintenance including brake pads & rotors, brake bleeds, oil changes, air & gas filter changes, sparkplugs, transmission fluid, serpentine belt. Replaced battery after 5 years - no indications that original battery was failing.
Overall no complaints but I think DIY has been critical in terms of cost control.
Old Dec 31, 2013 | 12:30 PM
bavmotors's Avatar
bavmotors
Sounds like that's a one in a million mini, is it a base model?
Old Dec 31, 2013 | 01:51 PM
rkw's Avatar
rkw
Even some of the most enthusiastic fans of MINI fidget nervously when the topic of reliability comes up. It isn't easy to find owners who will recommend a MINI for being solidly reliable. But they might recommend it for other reasons. You have to compromise between the car you want to drive and the risk of unreliability.
Old Dec 31, 2013 | 08:34 PM
xsmini's Avatar
xsmini
Originally Posted by bavmotors
sounds like that's a one in a million mini, is it a base model?
s
Old Dec 31, 2013 | 08:52 PM
bavmotors's Avatar
bavmotors
s
That's awesome! Of course she probably isn't modding or beating the cooper. Hope mine makes it that far.
Old Dec 31, 2013 | 10:38 PM
xsmini's Avatar
xsmini
No, it's pretty stock I believe, it's now semi-retired, she gave it to her son. Of course she replaced it with two others, a JCW, and a normal S.
My 03 is pretty modded and just turned 321,000
Stop waiting till spring, install that pulley already!
Nik
Old Jan 2, 2014 | 04:40 PM
jordan.burks's Avatar
jordan.burks
I have a 07 MCS with 60000 miles and she runs and drives just fine. a lot of people say bad things about the 07 and 08 MCS because they were the first years of the 2nd gen. I disagree though. just take care of her and she will run for a long time. you got to remeber when on these forums your going to hear more bad then good. just the nature of it. A 07 with 25000 miles is a good find!
