R56 So who thinks they know whats wrong with my car. Need Help!!!!
Old Dec 21, 2013 | 10:59 PM
ACTE's Avatar
ACTE
I drive a MCS 2008. So I just coming back from a 15 min drive then while dropping a friend off i left it idling for 10 mins. When I set off about 20 feet my car started moving really slow. i pulled up over and the idle was fluctuation up and down like in the video. Im thinking it might be a mass air flow sensor or a o2 sensor. Does anyone have an idea
Old Dec 21, 2013 | 11:11 PM
Ta87's Avatar
Ta87
What's the outside air temp?
Any mods?
Any weird sounds after shutting down the engine?
Any codes?
I had RPM fluctuations, but it was a valve cover leak. I had it taken care of and it's been running like a champ since... even during cold starts in -45 degrees.
Old Dec 21, 2013 | 11:21 PM
ACTE's Avatar
ACTE
The temp outside is cold. about 40. I have a alta hot pipe and i havent been able to run the code yet. Ill run them tomorrow with an update. The engine sounds fine it just stutters when shut off.
Old Dec 22, 2013 | 01:05 AM
CarlosDMotor's Avatar
CarlosDMotor
Have you ever had it carbon cleaned?
Old Dec 22, 2013 | 09:50 AM
ashchuckton's Avatar
ashchuckton
^^^ I think Carlos is right.
Old Dec 22, 2013 | 02:08 PM
ACTE's Avatar
ACTE
So I started the are up today and it seemed fine. its was driving strong till it warmed up all the way. I cleared the code and they came back up. The codes im getting are
p1497
p0507 Idle control system rpm higher than usual
1638 throttle valve position control, throttle stuck temporarily
1637 throttle valve position control; control deviation
Old Dec 22, 2013 | 04:01 PM
ACTE's Avatar
ACTE
So drove the car today and it was fine till it fully warmed up it goes into limp mode.
The codes I got were p1497 p0507 p1638 p1637
Help plz.
Old Dec 22, 2013 | 05:20 PM
CarlosDMotor
p1497-air leak downstream of throttle body. might want to try a smoke test to find any leaks
p0507-idle is too high, idle control not working. probably a result of p1638 and p1637
p1637/p1638-basically, the throttle body can't open/close as it wants to. This also could cause p1497 because the throttle body thinks its letting in less air than its supposed to. Search around the forums and you'll find better info and solutions
Old Dec 22, 2013 | 06:08 PM
ACTE's Avatar
ACTE
Thanks man. That really helps. I'll let u know soon. How do I do a smoke test?
Old Dec 22, 2013 | 07:51 PM
CarlosDMotor
Probably not something you can do, what they do is run smoke through your air piping at pressure and where it comes out that's a leak. But I'm not sure if I would do that because it could be the computer thinking there is less air because of the throttle not being at the correct place. Basically, you might not have a leak. Get the throttle body looked at first, see how it affects everything else. Has this only happened recently? I've heard that water can freeze in the throttle body and prevent it from moving
Old Dec 23, 2013 | 10:30 AM
ACTE's Avatar
ACTE
Do you think I might need to get a new throttle body? Should I pull the old one out and see if it gets stuck?
Old Dec 23, 2013 | 11:16 AM
CarlosDMotor
https://www.northamericanmotoring.co...puttering.html
https://www.northamericanmotoring.co...ilable-15.html
Seems like the intake manifold causes the problem. Maybe call dealer and see what they have to say
surfblue
Oct 24, 2018 01:20 AM
aldito2
Nov 25, 2015 09:33 PM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
elightbo
Aug 17, 2015 01:50 PM
