R60 Can the rear BENCH seat slide forward/backwards?
Old Dec 20, 2013 | 02:02 PM
CalsonicSE's Avatar
CalsonicSE
I have a 2013 CMS with rear BENCH seat. As most of you know, the bench seat is split 40/20/40. The outer sections each have a lever underneath to be ostensibly used to slide the section forward/backwards, just like the front buckets.
I lifted up each lever and tried sliding each seat with all my might, but they would not budge. Is something wrong with my seats? Can anyone confirm that the BENCH seat sections actually slide forward/backwards?
Old Dec 20, 2013 | 03:26 PM
etidd01's Avatar
etidd01
They do in my 2014.
Old Dec 20, 2013 | 04:39 PM
Gotham65's Avatar
Gotham65
I have a 2012 and both my seats slide foreward so there must be something with your seats.
Old Dec 21, 2013 | 12:11 AM
Sidewalker's Avatar
Sidewalker
Are you actually sitting in the seats? Mine are difficult to move unless I'm seated...has to do with leverage I think. Mine's a '13 and they move just fine.
Old Dec 21, 2013 | 06:52 AM
mikey_t's Avatar
mikey_t
Maybe its time to start working out....
Old Dec 21, 2013 | 07:03 AM
PepeR60's Avatar
PepeR60
+1. I have buckets, but mine required sitting in them or pushing them down as I moved them for quite some time before they seemed to break in.
Old Dec 21, 2013 | 09:46 AM
DR61's Avatar
DR61
My 2012 bench seats slide, when I sit in one and use the lever.
Old Dec 21, 2013 | 01:17 PM
CalsonicSE's Avatar
CalsonicSE
THANKS FOR THE TIP! I was not sitting in the seat when trying to slide it initially.
I got the driver side section to slide after sitting in it and using a moderate amount of pressure. However, the passenger side was SUPER STUCK. It FINALLY moved after I kept bouncing on it.
Kinda dumb that you have to climb into the vehicle and sit in the seat in order to move it, since its sole purpose is to create extra space when loading things in the boot.
Old Dec 21, 2013 | 02:04 PM
Quebecker's Avatar
Quebecker
My rear bucket seats took some serious brute force to move them. I was convinced they were broken.
Old Dec 21, 2013 | 10:00 PM
mikey_t's Avatar
mikey_t
My rear buckets slide fairly easily w/out sitting in them.
Old Dec 22, 2013 | 04:31 AM
shark715's Avatar
shark715
I noticed on both our '12 and '13 that the (bench) seats were initially very tight and you had to sit in them to move them, but after doing so a few times for some reason they become MUCH easier to move and you no longer need to sit in them to move them.
Old Dec 23, 2013 | 08:52 AM
enigmaintx's Avatar
enigmaintx
Mine slide forwards and back easily without ever having to have sat in the back seat. But then again, mine was on the showroom floor in the Mini dealership, so it's possible that someone "unstuck" them for me.
Cheers
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
kazyn
Oct 25, 2019 02:34 PM
Mini'mon
Aug 26, 2015 01:02 PM
pre shrunk
Aug 18, 2015 11:09 AM
