R52 need a part number for 2005 R52
Got it for you.
Looks like you need the outer weatherstripping below the side rear window.
Rear Weatherstrip Trim - Left ( driver side ) Part # 51367072931
http://www.ecstuning.com/Search/SiteSearch/51367072931/
Here is the one for the passenger side if you need it.
Rear Weatherstrip Trim - Right ( passnger side ) part # 51367072932
http://www.ecstuning.com/Search/SiteSearch/51367072932/
They clip onto the body at the top of the panel. #14
You are welcome, Not a problem, check the rear strip that goes all the way around the back, it matches those pieces, for deterioration since your there. Its the same designed strip that goes around the back. Easy to unscrew and install.
We have them in kits with and without the hardware ( screws and such ). The screws can really take a beating from salt and such and hard to put back in and tighten. Would be good to check the condition of yours.
Convertible Top Rear Trunk Molding Kit 51137123438KT
http://www.ecstuning.com/Search/SiteSearch/51137123438KT/
With install hardware:
Without install hardware:
Thanks again.
Thanks again.
ryGuyMCS
Oct 20, 2015 02:24 PM
Drivetrain Replacement MAF Sensor Plug Clip
absolutcamper
Aug 24, 2015 12:27 PM
Cal45fan
Aug 11, 2015 03:50 PM
