R50/53 Exhaust drone modulation/warble
Old Dec 2, 2013 | 07:31 AM
cubiclegnome's Avatar
cubiclegnome
I'm getting a strange warble with the exhaust drone in 6th gear. I believe one of my rear tires is out of balance or has a flat spot, as I can feel it. However, this seems to also create a strange modulated warble in the exhaust drone, similar to having two cars with loud exhausts next to each other on the highway. It's a fairly obnoxious sound, and could probably be solved by a tire balancing, but I'm curious to know if anyone else has experienced this.
Old Dec 2, 2013 | 07:54 AM
RockAZ's Avatar
RockAZ
Perhaps the heat shield or exhaust hanger is slightly loose?
Old Dec 2, 2013 | 09:04 AM
cubiclegnome
It's not really a buzzing sound but more of a deep warbling drone, that goes along with the tire rotation. Having the tires balanced would be a very cheap fix, but I'm only a few months out from needing a new set anyways.
Old Dec 2, 2013 | 11:06 AM
cerenkov's Avatar
cerenkov
You sure it's not a wheel bearing?
Old Dec 2, 2013 | 11:20 AM
cubiclegnome
Seems possible. I should probably throw it up on some jacks and give them a wiggle. It doesn't get worse when turning, but maybe that's not always a good indication.
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
potterstein
Sep 11, 2015 11:45 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
