R50/53 What is the best Diagnostic Scanner for a Mini?
Old Nov 30, 2013 | 11:24 AM
cartopics's Avatar
cartopics
Greetings Mini aficionado's...my son finally convinced me that he is old enough for his first Mini. We picked up a 2006 Cooper S with about 48K miles on it - one owner local to California. Had our mechanic look it over and all checked out. Now, in order to prepare for the future, what brand or type of diagnostic scanner do you guys use? Is it worth investing in a cheap (autozone) type scanner or a little more? I imagine the more you spend the more it "tells"?
Any input would be greatly appreciated!
Old Nov 30, 2013 | 11:37 AM
miles_miles7's Avatar
miles_miles7
Buy the scanguage 2. It packs lots of features i.e. serves as gauges, scanner and reset engine light.
Old Nov 30, 2013 | 01:38 PM
cartopics's Avatar
cartopics
Thank you for the input, however, the ScanGauge looks more like a "gimmick" that reads OBD codes...The Mini onboard computer already tells all the MPG,DTE etc. I was looking for something more professional that can actually help if needed - One of our friends has mentioned the Foxwell NT624 or the Foxwell NT644, has anyone ever tried these units out or owns one?
Old Nov 30, 2013 | 01:48 PM
Da_Ghost's Avatar
Da_Ghost
I've bought a Mac Tools ET123, a bit on the pricey side depending on how often you use it (300$), but it reads/erase engine, trans, abs, airbag codes. Compatible with all main brands, updates on Launch's website, etc. I might sounds like a salesman, but I'm not :p
Old Nov 30, 2013 | 03:31 PM
Martin Brenneke's Avatar
Martin Brenneke
scanner
The scan gague 2 does a lot more than just mileage. It give you a number of gague info that the mini dosn't. Look at there web site and you will see all that it can do for you. Have had one for over 2 years and wouldn't be without it.
Old Nov 30, 2013 | 04:36 PM
ACallahan's Avatar
ACallahan
I agree, the Scanguage is far from a gimmick I have had mine for years, currently have it displaying boost, water and oil temp and MPH. There are a number of different readings you can display, for the money it cant be beat, IMO.
Old Nov 30, 2013 | 05:51 PM
Longboard110's Avatar
Longboard110
As far as I know no code reader is going to diagnose your cars issues only give you a code. I have a scan gauge because of the amount of gauge versatility it offers along with the code reader.
Old Nov 30, 2013 | 06:41 PM
cerenkov's Avatar
cerenkov
If your going to buy a higher dollar one make sure that it can read BMW/MINI specific codes such as the Bavarian as seen here:
http://burgertuning.com/scanner.html
Old Nov 30, 2013 | 09:04 PM
borderwave2's Avatar
borderwave2
You need to get an INPA cable from onestopelectronics I believe. Then download INPA + WINPFK and you should be able to diagnose and code most everythig in the car.
Svejk
Feb 24, 2019 12:18 PM
oldkid6
Aug 11, 2015 08:13 PM
Dashdog
Aug 10, 2015 06:17 AM
2manyhobbies
Aug 9, 2015 06:02 PM
kwijmbo
Aug 5, 2015 09:00 PM
