R56 Metal buzzing/grinding sound 2013 mcs
Old Nov 28, 2013 | 05:01 AM
ptguy0618's Avatar
ptguy0618
Old Nov 28, 2013 | 06:36 AM
Beachnmini's Avatar
Beachnmini
Nah. I messed up with my paddles a couple times when I first got it, youre not the first lol. You should be alright unless you left it there and stood on it. Ft. Myers MINI is pretty good, they've been very good to me IMO.
If something happened you're car would light up like a Christmas tree.
Old Nov 28, 2013 | 07:33 AM
Drowninginlust's Avatar
Drowninginlust
Beachnmini the paddle shifters on an automatic wont let you destroy your engine the same way you can in a manual. Ptguy are you noticing any power loss?
Old Nov 28, 2013 | 08:11 AM
Beachnmini's Avatar
Beachnmini
Oh, well that is kinda good to know. But they did let me do exactly what he did so that why I spoke up.
Old Nov 28, 2013 | 08:21 AM
ptguy0618's Avatar
ptguy0618
Old Nov 28, 2013 | 08:23 AM
ptguy0618's Avatar
ptguy0618
Old Nov 28, 2013 | 08:33 AM
PenguinOnTheTelly's Avatar
PenguinOnTheTelly
Noise
How fast were you going? Was it a normal upshift at 2k-2,500k rpm or were you near your redline? To me it sounds more related to your transmission (i.e. synchronizer, chipped or cracked gear tooth or a main-shaft bearing) than your engine. The noise only occurs while travelling? Does the noise occur in neutral while revving the engine? If not I think you can rule out the engine. It almost certainly isn't turbo related. Regardless it is reassuring to know you're covered by your warranty. I'm sure they'll give you a loaner.
Old Nov 28, 2013 | 08:37 AM
ptguy0618's Avatar
ptguy0618
Old Nov 28, 2013 | 10:12 AM
PenguinOnTheTelly
Noise
Originally Posted by ptguy0618
I wasn't in rapid acceleration when I shifted from second to first, but the Rpms were high because drew out second gear for a while, so when it'll hit first it was enough to redline and jerk the car decelerating quickly.
And no I tried to replicate the sound in neutral, it only occurs under throttle or at speed.
One other way to isolate the problem to the trans would be to push in the clutch when you hear the whine. If it goes away immediately it's more than likely the trans. Well I'm sure it's aggravating but I'd be comforted knowing it'll get fixed via warranty. Something to be "thankful" for on Thanksgiving I guess. They may very well swap out the entire transmission rather than rebuild it. Like I said my dealer supplies free loaners so you can try a different car out for a bit.
Good luck.
Old Nov 28, 2013 | 10:14 AM
ptguy0618's Avatar
ptguy0618
Old Nov 28, 2013 | 08:11 PM
Drowninginlust
Yeah as for the loaner say you want to wait with the car. then you'll have to sit until the car is diaged, if there is damage to the engine or transmission that will take 2hours or longer to fix you'll get a loner.
Old Nov 29, 2013 | 04:08 AM
Beachnmini's Avatar
Beachnmini
Ft Myers MINI has given me a loaner every time I've been in for service. The only MINI I haven't driven now is the roadster. They're pretty good about that I think.
Old Nov 30, 2013 | 03:01 PM
Drowninginlust
Yeah we do our best but we only have so much to spend on loaners. ptguy i got you a new transmission approved. Some of the required parts are coming from Germany though so its gonna be a little bit =) Hope you were happy with our service.
Old Nov 30, 2013 | 03:05 PM
ptguy0618's Avatar
ptguy0618
Old Dec 1, 2013 | 08:48 AM
PenguinOnTheTelly
Good Service
Glad it worked out for you PT.
Old Dec 2, 2013 | 03:05 PM
ptguy0618's Avatar
ptguy0618
Old Dec 6, 2013 | 12:56 PM
ptguy0618's Avatar
ptguy0618
Old Dec 6, 2013 | 01:27 PM
cerenkov's Avatar
cerenkov
Did they say what was wrong with the transmission, was it from the money shift?
Old Dec 6, 2013 | 01:32 PM
ptguy0618's Avatar
ptguy0618
Old Dec 6, 2013 | 04:00 PM
Beachnmini's Avatar
Beachnmini
beach mini was that you that i waved back to on ft. myers beach this evening around 5pm? the car matched your little banner car, jw! if so im the assistant baker manager at the beach publix. stop by sometime!
It wasn't me, but I've seen another PW clubman that looks like mine down there. At 5 I'm usually driving back from Sanibel, I work over there.
But I do love some baked goods, and Publix!
Old Dec 23, 2013 | 04:08 PM
ptguy0618's Avatar
ptguy0618
Old Dec 26, 2013 | 02:36 PM
yanks4285's Avatar
yanks4285
I don't understand why you are not happy. Sounds like it's still related from you shifting from 1st to 3rd. you are very lucky they replaced the transmission under warranty when clearly it wasn't a warranty defect. just hope that they don't check the rev counter for over revs.
Old Dec 26, 2013 | 02:40 PM
ptguy0618's Avatar
ptguy0618
Old Dec 26, 2013 | 02:56 PM
yanks4285's Avatar
yanks4285
Simple, its a undesiged over rev.who knows how high you really got it past redline could determine how much damage was caused. It being your fault is accurate, you did shift it, right?
Old Dec 26, 2013 | 04:46 PM
AZdsrt's Avatar
AZdsrt
PT guy skipped town?
