Suspension Need Guidance:Front Sway Bar Bushing Installation
Old Nov 27, 2013 | 04:59 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Have searched to no avail. Want to install POWERFLEX Race front sway bar bushings w/o completely dropping the subframe. Can it be done relatively EZ by just removing the rear bolts and lowering just enough to gain access? What else would I need to do? TIA
Old Nov 27, 2013 | 07:04 PM
r34king's Avatar
r34king
You would need to remove the six in the rear plus one on each side. Essentially you want the front to be the only thing holding the sub frame on. Then you just need an 18mm wrench. But I'll let you know now they are in there tight. And might take all day unless you are using a lift. And you should replace the control arm bushings while you have all that loose
Old Nov 27, 2013 | 07:16 PM
NC TRACKRAT
Veteran: Navy
Already did the control arm bushings w/o lowering the subframe. Gee, that was fun! (But then, I love to suffer!) Will I need to detach power steering reservoir, coolant expansion tank, steering coupler, etc.?
Old Nov 28, 2013 | 07:30 AM
r34king's Avatar
r34king
Just the steering res and the steering coupler. Coolant tank has nothing to do with this job
Old Nov 28, 2013 | 11:22 AM
NC TRACKRAT
Veteran: Navy
Thanks, R34king! How far down can I lower the rear of the front subframe? Or will it just stop lowering on it's own when it reaches its limit? Anything else need support when it's lowered? No need to remove the front bumper cover?
Old Dec 1, 2013 | 01:53 PM
r34king's Avatar
r34king
It will stop on its own. But you can persuede it to go about another inch. No need to remove bumper cover. May want to unplug PS pump wires and fan wire just to be safe. Then its just the 4 18mm bolts
Old Dec 3, 2013 | 06:32 AM
NC TRACKRAT
Veteran: Navy
Thanks again! Checked the factory torque on the sway bar brackets: 125 lb.ft. No wonder it was a bear of a job! Was there room for a breaker bar?
Old Dec 8, 2013 | 07:17 AM
stover91's Avatar
stover91
since an 18mm wrench is recommended , double wrenching it may work better to get leverage. but i have not done this job so that is just a suggestion , not fact
Old Dec 8, 2013 | 09:13 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes if you take the subframe bolts out without unbolting it from the bumper it will stay in the car, but come down enough that you can get a wrench on the sway bar bush brackets. Loosen the bolts and you can slide the bushings out without removing the bracket all the way.
We keep the Race sway bar bushings in stock.
Old Nov 8, 2021 | 04:51 PM
Lex2008's Avatar
Lex2008
I need to do this job again. I've changed the end links and the sound goes away for a few months and then returns so must be the bushings failing, again.
Anyway I found 2 videos:
Old Nov 9, 2021 | 04:34 AM
deepgrey's Avatar
deepgrey
https://www.youtube.com/watch?v=9T96kJhRfx0
https://www.youtube.com/watch?v=zMb2HVpbqWk
Those videos aren’t for the R53.
Old Nov 10, 2021 | 07:04 AM
Lex2008's Avatar
Lex2008
Oh lord youre right...I posted to wrong group. Sorry 'bout that.
Old Nov 11, 2021 | 02:35 PM
deepgrey's Avatar
deepgrey
Oh. Oops. I see your sig now
Old Feb 4, 2022 | 07:29 AM
Soul Coughing's Avatar
Soul Coughing
i tried changing the bushings on my car without fully dropping the subframe and had a hard time getting enough torque to pull off the bolts holding the sway bar bushings. I ended up lowering it a couple inches, and it made it so much easier. For your sanity it's worth dropping it a little even if you need to undo more things!
Old Feb 4, 2022 | 09:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I couldn't imagine trying to get enough torque on those bolts to remove them without dropping the sub-frame completely. I had to get a 3/4" x 30" breaker bar on mine to get them loose. The torque spec on those bolts is over 100 ft-lbs.
Old Feb 5, 2022 | 08:14 AM
Lex2008's Avatar
Lex2008
I'm next...I did this 40k miles ago...changed the endlinks...still clanking...aftermarket bushings didnt last very long. Not looking forward to it.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
