R56 Bass speaker rattle
Old Nov 18, 2013 | 06:05 PM
TopLegion's Avatar
TopLegion
I am hearing a rattle when I play bass heavy songs in my mini. It specifically happens at low notes which makes me think there is something in the speaker. Has anyone had this problem or know how to fix it?
Old Nov 18, 2013 | 06:17 PM
Bob Saget's Avatar
Bob Saget
Dynamat. Odds are screws or clips have rattled loose too. Also could have a blown woofer (they tend to rattle too)
Old Nov 18, 2013 | 06:19 PM
Beachnmini's Avatar
Beachnmini
I would say the speaker is blown IMO. I'd replace them if it were mine.
Old Nov 18, 2013 | 06:57 PM
Bob Saget's Avatar
Bob Saget
If the speaker was blown, he would probably have distortion at other levels too.
OP, see if you can use the head unit to figure out which speaker it is (adjust fade and balance to each speaker). You may find out it's not the speaker, but the surrounding materials.
Old Nov 19, 2013 | 05:28 PM
Drowninginlust's Avatar
Drowninginlust
Almost every single rattle complaint Ive seen so far has been a seatbelt vibrating against the trim
Old Nov 20, 2013 | 08:03 AM
devicemanager's Avatar
devicemanager
Lightly push on the lower speaker grill and/or door trim to see if the noise disappears. You can then try felt shims in the door panel trim to see if it will resolve the issue.
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
Jim Ferrell
Oct 6, 2015 08:09 AM
patsum
Oct 1, 2015 06:33 AM
eliseo1981
Sep 30, 2015 07:57 PM
