Drivetrain Borla Agressive exhaust questions
Old Nov 17, 2013 | 04:47 PM
ti22fjc's Avatar
ti22fjc
Just wanted to know if anyone had and their thoughts. I know they are insanely expensive, but the SS construction will help in WI winters.
I would also like to keep, if not, increase the pop and burble noise-which is my favorite feature of my R53, and want to know if it increases or will I loose.
Old Nov 17, 2013 | 05:04 PM
ACallahan's Avatar
ACallahan
You will not look back, Borla systems are quality but you pay for that as well. Check youtube out for plenty of Clips of R53 w/borla.
Here is one:
Cease's Avatar
Cease
I just installed the Borla street exhaust. Very well made system, I asked my exhaust shop to weld it all in instead of using the clamps provided.
The street exhaust is about as loud as the one-ball mod and about the same burble-pop. It's exactly what I wanted, deeper growl, some pops but no drone on the highway. I can barely hear the exhaust under 3k with the windows up. Don't have hp numbers but the butt-dyno notices a slight gain.
Old Nov 18, 2013 | 04:57 AM
rwkeating's Avatar
rwkeating
Here is a great video about both the Borla exhausts for the R53 with dyno results and sound clips:
Old Nov 24, 2013 | 11:56 AM
sssevita's Avatar
sssevita
Borla Agressive Exhaust
I have the Borla agressive exhaust on my '03 MCS with the stock header / cat. It is louder than the JCW exhaust my car previously had and also has no highway drone. In the future I may remove the resonator and install a straight pipe in its place to make it a little louder.
Old Nov 24, 2013 | 12:03 PM
ti22fjc's Avatar
ti22fjc
That's great!! I JUST ordered the Borla aggressive. Had to confirm shipping address, if I ship home, wife would put me in a body bag.
Old Nov 24, 2013 | 12:17 PM
spr061's Avatar
spr061
I drive a base model r50 ... Would an aftermarket exhaust make a big difference?
Sent from my iPad using NAMotoring
Old Nov 24, 2013 | 12:30 PM
ti22fjc's Avatar
ti22fjc
Originally Posted by spr061
I drive a base model r50 ... Would an aftermarket exhaust make a big difference? Sent from my iPad using NAMotoring
I have read that any exhaust does after a bit of tuning. I have a KN air filter, so I'm not sure how much of a difference I would feel. Summit racing had a Borla for a Cooper, and what I thought was very reasonable.
Old Nov 24, 2013 | 12:55 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The Borla Exhausts don't sound bad, I've only had a few complain of drone with them on an R53. But I don't recommend them do to the failures I've seen with them. As you may have seen these have several joints to bolt together. While those joints make it easy to adjust they will all end up leaking, and the welds on the Borlas will all crack over time as every borla I've seen come in on an R53 was cracked and leaking.
I'd suggest the Stratmosphere Catback or Milltek. These have proven to be the most reliable over the years and make the most torque. With only 3 joints the potential for failure also reduces. And the pop and burble will be slightly amplified, but not too much where it is annoying. FYI they both cost less than the Borla.
Old Nov 24, 2013 | 01:14 PM
ti22fjc's Avatar
ti22fjc
Originally Posted by WayMotorWorks
The Borla Exhausts don't sound bad, I've only had a few complain of drone with them on an R53. But I don't recommend them do to the failures I've seen with them. As you may have seen these have several joints to bolt together. While those joints make it easy to adjust they will all end up leaking, and the welds on the Borlas will all crack over time as every borla I've seen come in on an R53 was cracked and leaking. I'd suggest the Stratmosphere Catback or Milltek. These have proven to be the most reliable over the years and make the most torque. With only 3 joints the potential for failure also reduces. And the pop and burble will be slightly amplified, but not too much where it is annoying. FYI they both cost less than the Borla.
Dang!!! Too late and the Borla just shipped... :(
The SS construction was a big plus, especially in WI winters. Wouldn't the issues fall under warranty??
Old Nov 24, 2013 | 01:26 PM
WayMotorWorks
Vendor
I've had them warranty them out, but you have to jump through the hoops and pay return shipping on the old exhaust for them to inspect it before they send you a new one. Not worth the time. Kinda like that commercial is the car reliable or the warranty???
Old Nov 24, 2013 | 01:33 PM
ti22fjc's Avatar
ti22fjc
I will see what I can do the Milltek w/o resonator was one I did look at, too.
Maybe I should just get an intake!
Aug 21, 2015 10:36 AM
WestfaliaR
Aug 19, 2015 08:01 AM
elightbo
Aug 17, 2015 01:50 PM
massmini03
Aug 12, 2015 11:19 AM
papawhiskey
Aug 10, 2015 09:31 PM
