R56 Graf Water Pump Warning
Old Nov 9, 2013 | 09:18 AM
jacknk's Avatar
jacknk
I bought the Graf water pump to replace my original water pump. After installing the pump I could not get the pulley on because the shaft on the Graf was too long. I was able to get my Dremel tool to the front of the shaft and grind enough off to get the pulley in place. It would have been much easier if I had realized this before installing the pump. So if you buy an aftermarket pump compare the shaft lengths with the original before installing. It is not a big deal but just be aware a problem could exist.
Old Nov 10, 2013 | 04:04 PM
ferrell.matthew's Avatar
ferrell.matthew
No offense, but there's evidence on these forums notifying the community on this same issue. Thanks for bringing it up again as this chassis getting to the point where a lot of the cars are needing the water pump replaced, but do yourself the favor and search before making any repairs. You could have saved yourself some headache!
ALSO! For what it's worth, I purchased the new updated, metal OEM water pump from Pelican Parts (I am not affiliated with this company by any means) for about half of the cost of the Graf pump.
Old Nov 10, 2013 | 04:58 PM
jacknk's Avatar
jacknk
For your information I did a search. I read the DIY on the water pump but I did not have time to read all the post. Sorry to offend you but I wanted to put the warning in the title so people would find it. If a warning was in a title then I did not see it. I also purchased the Graf pump from Pelican and it was the cheapest pump they had at $47.
Old Nov 10, 2013 | 05:28 PM
ferrell.matthew
I'm not offended, man! I just see it all too often on this forum where there's a lot of good knowledge covered up by a lot of generally uninteresting/unhelpful posts.
I didn't realize the Graf was so inexpensive. Maybe I was comparing my costs to my dealer's quote? Either way, for $15 on top of the Graf, the Saleri is definitely the easiest choice if you don't want to modify it to fit.
Since you've actually replaced your water pump, and modified it to fit, have you done any other repairs that are more on the difficult side?
Old Nov 10, 2013 | 05:39 PM
jacknk's Avatar
jacknk
I rebuilt the engine. It had suffered the tensioner problem and had head and piston damage. When I purchased the car it was not running.
Old Nov 11, 2013 | 06:24 AM
condor27596's Avatar
condor27596
Good information is worth repeating. Thanks!
Old Apr 30, 2014 | 01:51 AM
alexs3d2's Avatar
alexs3d2
I also used the Graf pump to replace the OEM plastic one. From the pictures I saw, it looks identical to the new OEM one, apart from the shaft length.
I removed the engine support completely on one side to be able to work, so the longer shaft was not a problem. The only thing I noticed, was that it makes a whinning-spund when the engine is cold. I am not sure it is the pump or the friction wheel, but the sound is there. When the engine is warm, I do not hear it.
Old Apr 30, 2014 | 06:07 AM
RockAZ's Avatar
RockAZ
Isn't this shaft length issue on the Graf only affected by the "S" model? Anyway, just had mine done with the updated all metal Mini one for my 2008.
patsum
26
May 29, 2021 06:29 PM
one73ronin
23
Sep 22, 2015 09:56 AM
cdemarco4
Sep 10, 2015 10:14 AM
Panik
Sep 9, 2015 08:36 AM
