R56 Lug Key
Old Nov 3, 2013 | 12:07 PM
cdboss's Avatar
cdboss
Lug Key
So a buddy and I were doing my rotors and pads. Whoever last tightened the lugs on the back wheels went pretty heavy on them and when were trying to take the key lug off the entire top of my key sheered off.
What exactly can I do at this point? Does the dealer sell them or is there some other way I can get these off without a tap and die?
If they're universal for Mini, which mine are factory, anyone in south jersey want to let me borrow theirs? Lol
Old Nov 3, 2013 | 12:38 PM
Agbullet25's Avatar
Agbullet25
If you have the little booklet that came with the locks, then the dealer can order you another key. The downside is it takes about a week or so to come in, since the dealer has to place an order with the lock manufacturer.
Old Nov 3, 2013 | 12:49 PM
cdboss's Avatar
cdboss
I don't know if I do. I bought the car used. Could these be tap and died out and just get a new lug key set?
Old Nov 3, 2013 | 02:15 PM
cdboss's Avatar
cdboss
A little update.
I'm taking the car up to Pep Boys tomorrow to get all 4 tap and died. Just going to put on 4 after market lug locks instead. It makes me kind of cringe to bring it to them but, I don't really have a choice right now. 2 of the lugs are loosened on the front, not torqued and I can't torque them so, I can't really wait a week.
Pep Boys is the closest to me and they said they'll tap and die all 4 for 50 bucks so, that's not too awful. Going to continue my brakes tomorrow myself, which stinks buts, need to get them on there.
Old Nov 3, 2013 | 03:54 PM
danjreed's Avatar
danjreed
Pound an socket over the outside of them. They come right off, Ive never met a set I cold not have off in 20 seconds this way.
Old Nov 3, 2013 | 04:16 PM
Bob Saget's Avatar
Bob Saget
Use a torque wrench next time. You shouldn't be cranking them down as tight as you can. 90 ft/lbs at max. I think the manual says they're supposed to be torqued to like 82
Old Nov 3, 2013 | 04:18 PM
Agbullet25's Avatar
Agbullet25
He said he didn't torque the back wheels, which caused the problem. Someone else did.
Old Nov 3, 2013 | 04:32 PM
cdboss's Avatar
cdboss
What do you mean by this? Can you clarify a little bit?
cdboss's Avatar
cdboss
This is correct. I did not torque the back wheels a shop did it.
Old Nov 3, 2013 | 05:25 PM
Slave to Felines's Avatar
Slave to Felines
Take a socket that is just a little too small for the outside of the lock. Put it over the lock, then hit the snot out of it with a BFH. (Thst' short for Big Hammer.) It should go on. Then you can plug a breaker bar into the socket and loosen the lock.
I don't bother with wheel locks, myself; I've had some close calls and have decided that it isn't worth it to use them.
Old Nov 3, 2013 | 05:29 PM
cdboss's Avatar
cdboss
Honestly, I'm thinking of just buying a lug set and throwing them onto the car. The wheel locks have been quite annoying with shops forgetting to get them back to me and me forgetting them when I take it to a shop.
This is just the icing on the cake. So you mean just push a socket onto them and I should be able to get them off using like a torque wrench or something?
If it works, it'd be great to save 50 bucks, lol.
Old Nov 3, 2013 | 06:20 PM
danjreed's Avatar
danjreed
Honestly, I'm thinking of just buying a lug set and throwing them onto the car. The wheel locks have been quite annoying with shops forgetting to get them back to me and me forgetting them when I take it to a shop. This is just the icing on the cake. So you mean just push a socket onto them and I should be able to get them off using like a torque wrench or something? If it works, it'd be great to save 50 bucks, lol.
Use a breaker bar... Not a torque wrench..
Never use a TW to loosen fasteners.
Old Nov 3, 2013 | 06:23 PM
cdboss's Avatar
cdboss
I was actually using a breaker bar when trying to remove the back ones, lol. Well I'm going to try this tomorrow. If I can't manage to get it to work, I'll just go get them off with a tap and die.
Old Nov 3, 2013 | 06:53 PM
nine5raptor's Avatar
nine5raptor
Use an impact socket. The standard ones can shatter. Also if you have a pipe, slip it over the breaker bar for more leverage. I have a 6 ft pipe for my 2 foot bar. Also vibrations can help. While holding a torque on the bolt, tap the breaker bar with a hammer to loosen.
Old Nov 3, 2013 | 06:54 PM
cdboss's Avatar
cdboss
Yeah my buddy let me borrow his impact sockets. I'll try my best not to damage them, lol. I need to get me a set of them.
freckles81
Jan 15, 2017 06:33 AM
JamesDeBart
Apr 16, 2016 05:00 PM
newminijcw
Oct 21, 2015 02:37 PM
jennster
Sep 28, 2015 06:19 PM
