Will 215/55 R17 fit?
Old Oct 29, 2013 | 02:38 PM
Nowheat's Avatar
Nowheat
Will these fit on factory 17" wheels with no rubbing? I do have the factory sport suspension.
Old Oct 29, 2013 | 07:53 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I assume you want this to fit on your 2006 MCS.
No it would not fit and very likely rub.
Stock tire size is 205/45-17. The second number is the sidewall profile, it is 45% of the 205mm width. Stock tire diameter is about 24.3"
215/55-17 can fit on a stock 17" wheel but is too tall at 26.3" tire diameter or 2" taller than OEM. Using stock suspension there is no room for the tire and any travel.
Old Oct 30, 2013 | 03:05 AM
Nowheat's Avatar
Nowheat
Thanks minihune. I'll stick with stock size.
Old Oct 30, 2013 | 05:44 AM
Trizzz's Avatar
Trizzz
215/45/17 will fit not 55
Old Nov 3, 2013 | 06:35 PM
Nowheat's Avatar
Nowheat
Can I run 215/50/17 blizzak ws70 winter tires?
Old Nov 3, 2013 | 08:08 PM
Trizzz's Avatar
Trizzz
if you are not lowered yes
Old Nov 3, 2013 | 10:27 PM
minihune's Avatar
minihune
It will barely fit and is not recommended, some risk for rubbing since it is taller and wider than OEM at 25.5" tire diameter vs 24.3" OEM. At $154 each it is not the best value.
Not sure why you would choose that size since in the WS70, you can also choose:
215/45-17 $144 each, 24.7" tire diameter
205/50-17 $137 each, 25.1" tire diameter
In general you want a winter tire that is more narrow to cut through deep snow, and not much taller than OEM for more clearance.
Old Nov 4, 2013 | 10:01 AM
Nowheat's Avatar
Nowheat
I just thought they might work as I found them for a real cheap price used with less than one season on them. I'll just stick with a 205/45/17 for winter.
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
