Interior/Exterior Jcw
JCW package is a rip off, you can do a CAI, 380cc injectors and after market cat-back exhaust and a tune for half as much as a JCW package. The JCW did have a very mild port job on the exhaust side, but not enough to make much difference. you do the above mentioned things and you will essentially get the same performance as a 05 factory JCW for less money.
That being said, you asked what it cost: about 6k$ and that does not include the installation. Now if you did order one, you could sell off your SC, & Head and get a quick 1k$ back.
So like he said, you are far better off, just getting the equivalent mods and installing them your self:
- Cold Air Intake - they start about 150.oo and you can get a JCW one for $325
- Injectors - JCW 380cc ~400$ after market 380cc about ~300 or less (search for the thread on this)
- Exhaust - JCW (new) right at a 1k$ After-market from $350 to A LOT.
- Head - JCW I do not know and would not even bother with, if you really want to spend the money to have the JCW name and a piece of Paper then go for it, if not get one of the MINI specialty shops Head Thumper, RMW, Hell even the Cosworth!
- Tune - you can get the JCW tune from the dealer, if you have the other mods, for usually 1 hour labor (est 150$)
- Badges & Stickers - Most can be found on the bay at affordable prices if you want the look.
- Brakes - JCW Kits Range from the DIY (which I did) for about 400.oo$ to 2500 for the TRUE JCW BBK
- Pulley/Supercharger - in the kit is a supercharger that has coated rotors (which came on the 05 and 06) and a pulley that was about 11% reduction. You can get aftermarket from 15 to 19% for about $100
So I would suggest: (all prices are estimates and depending on Brand and Model should be adjusted)
GP Intercooler - 550$
Injectors - 400$
Pulley - 100
Exhaust - $700
Header - $500
Tune - $350 (get custom)
Brakes - $450 - DIY JCW R53 to R56 Conversion
These things are NOT listed in order as I would suggest Pulley FIRST, its the MOST Bang for the Buck!
Other things I would suggest:
ATI Dampener - $350
Lower Control arm Bushing PowerFlex $100
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
