R56 Is the little metal key waterproof?
I know the whole fob is not, but if i take out the little key that unlocks the door can I get it wet? Seems like ti should be OK, but who knows what microchip is in there!
Need to know if I should keep it in a dry bag for kayaking.
Thanks!
Thanks!
Mmmm the key fob is definitely water resistant I've heavily washed it before when I shined a uv light over it. As for the metal key I think it's resistant but I would imagine like any metal it can still oxidize and rust if left out. Also the micro chip is in the fob itself. As far as I know. You can't start the car without the metal key and just the fob. I think the key itself is just a regular tumbler lock
Sent from phone
I'm not whether or not your have a air tight seal lock somewhere on your kayak but you should be fine to take it with you in the kayak. Assuming you don't flip over. Or you could just lock the fob in the car with the key lock. as long as you dry it you should be okay.
Sent from phone
Sent from phone
I lock the fob in the car and take the key with me when I go dinghy sailing. Yes it is waterproof, I've tested it a time or two...
Thanks everyone!
I plan to lock the fob in the car, just wanted to see how careful to be with the other part!
For the R53 I just left the little plastic key in my life vest!
Thank you!
Thank you!
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
