R56 vacuum leak, error P1497
Old Oct 20, 2013 | 08:52 PM
Shamaim's Avatar
Shamaim
Hello gang,
I have an R56 2007 Mini Cooper S that's recently started to show the P1497 CEL.
Besides the code, the car's idle becomes bouncy at times and the engine is making what seems to be a whistling sound from the top right corner (when looking at the engine from the front of the car).
How may I exactly determine whether it's the valve cover or other part that needs replacement?
Thank you!
Old Nov 8, 2013 | 05:45 PM
shanksamillion's Avatar
shanksamillion
Hello,
I think this is probably a bad valve cover/cylinder head cover. Mini integrated the pcv into the valve cover and that is the part that causes the leak.
Old Aug 14, 2021 | 05:06 AM
kikoman4's Avatar
kikoman4
Hi Shamaim,
I have the same codes P1497, While im on the road driving i heard a whistling sound after a couple miles engine light came on.
Just a quick question to you my friend, Is your mini issues got fix? Any answer will be highly appreciated.
Thanks,
Old Aug 15, 2021 | 06:22 AM
GsxR1000's Avatar
GsxR1000
Hello guys,
I have a 2009 mcs w/ 169K miles. When I had the P1497, I resolved it by replacing valve-cover and the pcv hose that goes from rear-passenger side of valve cover to bottom of intake.
Good luck,
W
Old Aug 17, 2021 | 09:24 AM
Mineeee's Avatar
Mineeee
Might not be the valve cover / oil separator that has failed. In my case the hose from the valve cover had simply come loose as the clip mechanism had broken. The vacuum side hoses are notorious for cracking too, they are a sort of serrated hard plastic that can become brittle and crack. Its fiddly to check that as the hose runs down and under the inlet manifold.
Old Sep 25, 2021 | 04:23 PM
kikoman4's Avatar
kikoman4
HI Guys,
I have a 2010 MCS and just replace my valve cover due to a whistling sound, after all the jazz, start the car came up a new issue, after opening the oil cap starting to rough idle.
I need your help guys, please...
KWStan
Apr 13, 2018 02:57 PM
DuffyMule
Jul 7, 2017 10:27 PM
supereek
Jul 24, 2014 08:13 AM
bluejae
Nov 8, 2013 06:19 PM
mamut
Feb 29, 2012 05:53 AM
