Suspension Sway bar bushing replacement
Old Oct 16, 2013 | 08:16 AM
Quitman Rhinehardt's Avatar
Quitman Rhinehardt
Is it possible to replace them without dropping the sub frame?
Old Oct 16, 2013 | 10:00 AM
RadioActiveMan's Avatar
RadioActiveMan
I'm in the process of dropping my subframe to do Control arm bushings, sway bar bushings and ball joints.
When I was looking at the sway bar bushings last night it looked like it might be possible. Its tight in there though.
Old Oct 16, 2013 | 11:37 AM
Quitman Rhinehardt
Yeah I know its tight. I'm hoping to get away with just loosening the clamp and slide old off then the new on. I should have just went ahead and tried while I did the control arm bushings but since I didn't drop the sub frame to do them I figured another day sounds good. lol
Old Oct 16, 2013 | 06:19 PM
scoopy's Avatar
scoopy
let us know if you can change the bushing without dropping the subframe.
Old Oct 16, 2013 | 07:41 PM
Quitman Rhinehardt
Friday I will attempt the drivers side since I am replacing that axle anyway. I'll let you guys know how I make out.
Old Oct 17, 2013 | 12:14 PM
Quitman Rhinehardt
The forward bolt on the sway bar bushing is on REAL tight. I'm soaking it with pb blaster for a couple days and will attempt again. There isn't a lot of room for a breaker bar but my 18mm wrench with another wrench hooked on the end to give more leverage wouldn't budge it.
Old Dec 9, 2013 | 01:18 PM
98oilhead's Avatar
98oilhead
Sway bar bushings
If you are talking about the rear, yes, you can replace the bushings without dropping the subframe..tight and a little fiddly but just did it on a 2003 S
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
