R60 What bulbs do I need??
Old Oct 10, 2013 | 01:14 PM
alizzo's Avatar
alizzo
Can someone please help me out?
I want to replace all my headlight and foglight bulbs out with Nokya Yellow bulbs.
I'm not sure which exact ones I need to change out those specific bulbs. I don't care about the high beams as I rarely use those anyway, not sure if this even matters or not.
Thanks!
Old Oct 11, 2013 | 08:05 AM
alizzo's Avatar
alizzo
Please... Don't everyone reply at once now...
Old Oct 11, 2013 | 08:19 AM
sbdubya's Avatar
sbdubya
Why don't you go pull the ones in your car and get the # off of them? I know that MINI uses two different turn signal bulbs (which means they might use other types of bulbs) and it depends if you have xenons for headlights. Once you have the bulb #'s from your car then you can order the correct ones.
alizzo's Avatar
alizzo
Good idea. Fanx.
Old Oct 11, 2013 | 08:57 AM
ke3ee's Avatar
ke3ee
There are a bunch of threads about this, do a search. I installed a 3800K(yellow) HID foglight kit from Burger motor sports. Install took less than 30 including jacking up the car on the drivers side. They look great. The fogs are H8's and the headlights are H13 I believe.
Old Nov 4, 2013 | 07:08 PM
tigerwong58's Avatar
tigerwong58
I installed Nokya Yellow turn signal modified 1156. Foglights H8 and parking light above foglight 194. It looks good
Oct 1, 2015 12:13 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
