R60 What bulbs do I need??
Can someone please help me out?
I want to replace all my headlight and foglight bulbs out with Nokya Yellow bulbs.
I'm not sure which exact ones I need to change out those specific bulbs. I don't care about the high beams as I rarely use those anyway, not sure if this even matters or not.
Thanks!
Thanks!
Why don't you go pull the ones in your car and get the # off of them? I know that MINI uses two different turn signal bulbs (which means they might use other types of bulbs) and it depends if you have xenons for headlights. Once you have the bulb #'s from your car then you can order the correct ones.
There are a bunch of threads about this, do a search. I installed a 3800K(yellow) HID foglight kit from Burger motor sports. Install took less than 30 including jacking up the car on the drivers side. They look great. The fogs are H8's and the headlights are H13 I believe.
Oct 1, 2015 12:13 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
