R56 Check engine light
Old Sep 28, 2013 | 02:13 PM
Spock33's Avatar
Spock33
Check engine light
Check engine light has come on again but it's not putting out any codes on the obd. Second time this is happened. The light turned itself off after a few days the first time but was wondering if anyone has run into this issue before.
Old Sep 28, 2013 | 02:25 PM
rhygin's Avatar
rhygin
Are you checking with a device that has the ability to read BMW/MINI specific codes?
Old Sep 28, 2013 | 03:20 PM
Spock33's Avatar
Spock33
I think so. Obd2 reader was supposed to be able to I thought. Advance, auto zone can't read the codes. It appears to communicate but it said no codes present
Old Sep 28, 2013 | 03:33 PM
rhygin's Avatar
rhygin
I'm not familiar with the specific reader you're referring to. Some others with more experience may be able to address that question.
For me, I found that the generic code reader that came with an iphone app I use (Dashcommand, connected to OBD2) is able to read generic codes only. For example, when my HPFP was dying, it could read the cylinder misfire (P30x) codes, but not the 2880 high pressure system code. When I brought the car to my BMW-specific independent shop, their code reader (Bavarian Technic?) was able to read the additional engine codes (and some codes for other systems that I couldn't read).
Sorry, that's all I can offer. Good luck with your light.
Old Sep 28, 2013 | 04:07 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Any other symptoms which could be associated with the code ?
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
