Having a cabrio is like having a pickup....tons of...er...junk can get tossed in if you leave the top open.....I hope...unless it from your teenaged daughter.... Then negative I hope!! Lol.
I'd assume something left behind from the factory?
I believe it is a plastic key blank. You can cut this so it opens your doors. You can also buy these cut from MINI for a wheel barrow full of money. I needed one for my '05 so the steering wheel would not lock when I towed it. In 2008 they were about $70 cut. Probably a good key shop can cut it from your key so it will open your door. That's my two cents for what it's worth.
Maybe it's an RFID tag used to track the car through the different steps of the fabrication process (?)
I have to say it does look like the key. Is it actually the same size and can you get the car started with it? . . . idk...
It appears to be an uncut wallet key, from reading around that's what its said to be too. I wouldn't toss it tho becasue all though uncut I think that dark part looks like the chip for the car to read.
I kept it, if for no other reason than to have some cool MINI memorabilia. Apparently rare it could be, seeings how nobody has seemed to have seen one of these before.
