bought a r50 mini with supercharger help
Old Sep 23, 2013 | 05:01 PM
Chris Gutierre's Avatar
Chris Gutierre
well i bought this mini in a insurance auction its a r50 5 speed with a supercharger and it had fire damage. the engine bay lit on fire from a loose fuel line. most of the engine harness melted and a couple of vac hoses. i replaced everything all the vac hoses and harness . now the only way i could get the car to start is if i put two map sensors instead of one tmap and a map. it starts just fine with two map sensors it revs normally but dies on deceleration. also when i put it in gear and drive it, it has no power and of course i get a error code for no air temp. but when i put the tmap in front on the manifold and a regular map sensor in the back it doesnt even start? i get error code p1106 when i do and i bought the tmap from the dealer. the hugest problem is i dont know if it ran well before.oh and i just realize that the ecu could be a problem because its a regular r50 ecu (matches the vin) but maybe it was reprogrammed with progman? i really need to get her up and running right i have alot of money invested this car. i didnt know this car was going to be a pain in the butt.
Old Sep 23, 2013 | 06:16 PM
JAB 67's Avatar
JAB 67
Are you sure that someone put a supercharger on a base model with 5-speed? Ill-advised to put it mildly . . .
Old Sep 23, 2013 | 06:58 PM
Chris Gutierre
yes im sure. i first found out when i ordered parts and they wouldnt fit. for example the transmission mount/support its different for 5 speed than a r53 6 speed. also when i got a r53 harness the injector clips were different. the battery was in the front. you know stuff like that
Old Sep 23, 2013 | 07:04 PM
ZippyNH's Avatar
ZippyNH
You bought somebody else's project car....
Been done before....somebody always wants to prove it can be done...
Hate to see how long a 5 speed will last...they fail fast with just the r50 HP...mini changed the trany in 2005+ coopers due to this issue...
My suggestion...
Cut your losses, and sell it before you sink $$ to get it running...then have the tranny fail...then fix that to have the weaker r50 internals fail....
The bodies of the r-50 and r53 are the same, and drivetrain is similar...but different for a reason....
Old Sep 23, 2013 | 07:37 PM
ACallahan's Avatar
ACallahan
Not to mention the valves on a R50 head will be fried by the supercharger heat. Hope they put a R53 head on when they added a supercharger.
theateist
Jul 2, 2017 02:21 PM
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 26, 2015 01:02 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
cjsdad
Aug 11, 2015 08:46 AM
