Drivetrain Had a couple of suspension parts installed today:
Old May 13, 2004 | 07:17 PM
ColoradoMark's Avatar
ColoradoMark
Picked these up from Randy this morning and had them installed today at Bimmerhaus. They also aligned and corner weighted the car
_________________
IB/W some mods
Old May 13, 2004 | 07:22 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Kudos! You are now among the 1% of coilover owners who actually have your cars corner balanced.
Those look nice and VERY easily adjustable!
_________________
SHOW ME THE NUMBERS!
...How Fast is Your MINI?...My Mods...
Old May 13, 2004 | 07:34 PM
TonyB's Avatar
TonyB
Very nice CM! I'm envious and happy at the ame time...
So, what did she weigh? When time permits, share some photos installed. Enjoy!
Old May 13, 2004 | 07:40 PM
ColoradoMark
2,680 1/4 tank of gas, before I got in the car. 60/40 weight distribution. I didn't write down the individual corner weights - it was a long day!
Old May 13, 2004 | 07:44 PM
Ryephile's Avatar
Ryephile
[drool] Leda coilovers RULE
are those Randy's new camber plates snuck into the shot?
Nobull60's Avatar
Nobull60
Looks like a nice setup but could you make the picture a tad larger so I can see it on my 60" wide screen TV, It;s just an inch to small to fit the whole screen
Old May 13, 2004 | 07:52 PM
TonyB's Avatar
TonyB
Understood. A long day, but I'm sure well worth it! Randy hooked you up with what many would call the best suspension goodies. Look forward to hearing your impressions on the track...
Old May 14, 2004 | 03:07 AM
jlm's Avatar
jlm
cool I've hd a set on order for 6 weeks...must be the ship has landed. mine are coming from RC racing. what spring rate did you ask for? nice to see someone go whole hog.
Old May 14, 2004 | 06:56 AM
ColoradoMark
Sorry - still trying to figure out this whole internet picture posting thing, coupled with a new camera.
Old May 14, 2004 | 07:02 AM
andy@ross-tech.com
Here's a nice free image editing program:
http://www.irfanview.com/
Old May 14, 2004 | 07:21 AM
FWD-MX5's Avatar
FWD-MX5
Very . Couple of questions-
What else do you have on your car to make it 2600+ lbs?
Do the Ledas have their own upper mounts or do you use the stock Cooper bits?
I am thinking of going STS and if I do Randy will be my first call for the Ledas- once I get back from my Uncle Sam's sponsored desert vacation.
Old May 14, 2004 | 08:01 AM
ColoradoMark
I thought 2685 was pretty close to stock. I've added a roll bar and have a one-ball muffler. Didn't weigh the Stoptech's, but I have lightweight wheels on the car (SSR comps). Car wasn't completely cleaned out, miscellaneous stuff inthe glove box and the boot.
Old May 14, 2004 | 08:16 AM
ColoradoMark
Another pic from the rear during the install, Jim wouldn't show his face.
Old May 14, 2004 | 08:25 AM
samawil's Avatar
samawil
Nice set up man :smile:
What exactly is corner balancing and how is it done?
Also, like Rye said, are those the new camber plates Randy was working on?
L
Old May 14, 2004 | 08:44 AM
ColoradoMark
The camber plates are RDR's.
Corner weighting is a way to balance the weight distriution of the car by adjusting the ride height of the coil-overs. The car is put on four scales, you set the initial ride height by eye, or tape measure, then fine tune the weight on each corner by raising or lowering each corner of the car.
Old May 14, 2004 | 11:01 AM
jlm's Avatar
jlm
not quite; the goal is to make the diagonal weights equal by adjusting the spring perches. The only way to change individual wheel weight, or LS vs RS, or F vs R, is by moving ballast around.
it is done with scales under each wheel and on an level base and the ride height approximately where you want it: think of it this way...if you were to back off the spring perches on each end of only one diagonal, the car would eventually balance on the other diagonal and rock on that axis like a four legged table with one short leg. You would then have 0 lbs for one diagonal weight and the entire car weight for the other. The idea is to adjust until each diagonal weight is the same.
It should be done with a driver's weight in the driver's seat and about 1/2 tank gas. every time you do the spring adjustment, you have to roll off the scales, access the spring perchs and turn them on opposite ends of the diagonal you are setting, roll back on the scales to make sure tire scrub is eliminated and see what you get.
Old May 14, 2004 | 11:09 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
ColoradoMark,
Thanks for the pics and post. What are you going to do with this setup? Autocross solo 2 and solo 1?
Track events? Let us know how your MINI drives on the street. Why did you get the rollbar (solo 1?)?
Let us know how the setup works for you on the track or at Solo 2.
Should be great.
Cost of the suspension upgrades? Parts and labor?
Cost of the rollbar? Parts and labor?
Aloha
Old May 14, 2004 | 11:21 AM
MSFITOY's Avatar
MSFITOY
envy lust jealous envy lust jealous envy lust jealous envy lust jealous envy lust jealous envy lust jealous envy lust jealous envy lust jealous envy lust jealous
_________________
Old May 14, 2004 | 01:14 PM
ColoradoMark
>>ColoradoMark,
>>Should be great.
>>Aloha
Autocross, open tracks days and time trials. Rollbar not required for any of these, but nice to have.
Costs: Jeeze do you tell people how much your MINI costs?
Cost: Rollbar ~500 plus install
Suspension: Parts ~$3000 Install ~$500
Mark
Old May 14, 2004 | 02:38 PM
Bisch's Avatar
Bisch
Smile on face while driving: priceless
:smile:
Old May 16, 2004 | 01:59 AM
03Indigo's Avatar
03Indigo
User Title's are Silly
Mark, this is the first chance I have had to look this up...you should show the shot of the front with the Stoptech front brakes.
Having been there in person while this was going on, I can say it was educational as well as a good time. Mark, thanks for inviting me along to see it all go down.
cheers
jon
Old May 16, 2004 | 03:07 AM
d-mini-ero's Avatar
d-mini-ero
Looks terrific :smile:
I recently drove vdubdougs car w/ coilovers and I did enjoy the feel and difference in handling.
Good luck and all good things
(PS...I'm making notes for my new MCS...if and when it comes to be
Old May 17, 2004 | 07:24 AM
ColoradoMark
>>cheers
>>jon
Glad you came. They were great at the track this weekend. A little bit of rubbing on the fender liners. I either need to raise the car a bit or add more camber. It was fun spanking an SVT Cobra Mustang (and not a stock one at that).
maestro39
Oct 27, 2015 02:38 PM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
