Drivetrain Had a couple of suspension parts installed today:
Kudos! You are now among the 1% of coilover owners who actually have your cars corner balanced.
Those look nice and VERY easily adjustable!
_________________
SHOW ME THE NUMBERS!
...How Fast is Your MINI?...My Mods...
_________________
Understood. A long day, but I'm sure well worth it! Randy hooked you up with what many would call the best suspension goodies. Look forward to hearing your impressions on the track...
>>Looks like a nice setup but could you make the picture a tad larger so I can see it on my 60" wide screen TV, It;s just an inch to small to fit the whole screen
Sorry - still trying to figure out this whole internet picture posting thing, coupled with a new camera.
Very
. Couple of questions-
What else do you have on your car to make it 2600+ lbs?
Do the Ledas have their own upper mounts or do you use the stock Cooper bits?
I am thinking of going STS and if I do Randy will be my first call for the Ledas- once I get back from my Uncle Sam's sponsored desert vacation.
. Couple of questions-What else do you have on your car to make it 2600+ lbs?
I thought 2685 was pretty close to stock. I've added a roll bar and have a one-ball muffler. Didn't weigh the Stoptech's, but I have lightweight wheels on the car (SSR comps). Car wasn't completely cleaned out, miscellaneous stuff inthe glove box and the boot.
The camber plates are RDR's.
Corner weighting is a way to balance the weight distriution of the car by adjusting the ride height of the coil-overs. The car is put on four scales, you set the initial ride height by eye, or tape measure, then fine tune the weight on each corner by raising or lowering each corner of the car.
not quite; the goal is to make the diagonal weights equal by adjusting the spring perches. The only way to change individual wheel weight, or LS vs RS, or F vs R, is by moving ballast around.
it is done with scales under each wheel and on an level base and the ride height approximately where you want it: think of it this way...if you were to back off the spring perches on each end of only one diagonal, the car would eventually balance on the other diagonal and rock on that axis like a four legged table with one short leg. You would then have 0 lbs for one diagonal weight and the entire car weight for the other. The idea is to adjust until each diagonal weight is the same.
It should be done with a driver's weight in the driver's seat and about 1/2 tank gas. every time you do the spring adjustment, you have to roll off the scales, access the spring perchs and turn them on opposite ends of the diagonal you are setting, roll back on the scales to make sure tire scrub is eliminated and see what you get.
ColoradoMark,
Thanks for the pics and post. What are you going to do with this setup? Autocross solo 2 and solo 1?
Track events? Let us know how your MINI drives on the street. Why did you get the rollbar (solo 1?)?
Let us know how the setup works for you on the track or at Solo 2.
Should be great.
Cost of the suspension upgrades? Parts and labor?
Cost of the rollbar? Parts and labor?
Aloha
Should be great.
Aloha
>>ColoradoMark,
>>Should be great.
>>Aloha
Autocross, open tracks days and time trials. Rollbar not required for any of these, but nice to have.
Costs: Jeeze do you tell people how much your MINI costs?
Cost: Rollbar ~500 plus install
Suspension: Parts ~$3000 Install ~$500
Mark
>>Should be great.
>>Aloha
Mark
Mark, this is the first chance I have had to look this up...you should show the shot of the front with the Stoptech front brakes.
Having been there in person while this was going on, I can say it was educational as well as a good time. Mark, thanks for inviting me along to see it all go down.
cheers
jon
cheers
jon
Looks terrific :smile:
I recently drove vdubdougs car w/ coilovers and I did enjoy the feel and difference in handling.
Good luck and all good things
(PS...I'm making notes for my new MCS...if and when it comes to be
>>cheers
>>jon
Glad you came. They were great at the track this weekend. A little bit of rubbing on the fender liners. I either need to raise the car a bit or add more camber. It was fun spanking an SVT Cobra Mustang (and not a stock one at that).
>>cheers
>>jon
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
