Navigation & Audio iOS 7? Mini Connected working ok? iTunes Radio?
iOS7 & iPhone 5 - Not Working
I've been in a slow connectivity downward spiral....
Everything was working fine with my iPhone 5 running IOS6 - including receiving text messages via Office.
I got my iPhone 5 replaced a few weeks ago because the power button was failing - with the replacement I lost the text messages and none of the earlier fixes are working...
Upgraded to IOS7 and now I don't have audio unless I go exclusively through the Aux input. If I select my phone through USB, the phone reacts like it's playing and the Connected display shows the track progressing - but there's no sound... So that I have the length I'm using the Apple cable and a separate audio cable to connect to the MINI. I have yet to pull out my old solution of the MINI Y cable and an adapter to see if that works...
From MINI Victoria on my Facebook newsfeed:
Did you update your iPhone to the OS7? Having trouble pairing your device? Just remove your current device from your MINI and add a new phone to re-pair!
Yea this fixed everything for me after the update.
Weird, everything works fine in my brother's clubman but mine won't let me skip through tracks on my playlist when using my iphone 5 (iOS7) and Bluetooth.
Can't skip tracks unless I pick up my iphone and skip through, the steering wheel controls and the **** are unresponsive.
I tried deleting phone and repairing it with no luck.
Has anybody found the settings to get email showing up? i have the text messages showing; but have never found the way of getting emails (even under IOS6)
I use my phone like a iPod. Sit in my car select blutooth phone and play music.
I don't plug in my phone unless I am using google send to car.
I'm on a slow downward spiral as well with my iPhone 4S. Everything worked fine a year ago when the car was new, but with each successive software/OS upgrade, I began to lose functions. First, the forward/back would not go to the indicated track. More recently, a viewed/selected playlist does not play when selected, but instead it plays the first track of my music library, no matter what I select on the connected screen.
I now have to resort to making every track/podcast selection directly from my iPhone screen, which is unsafe and defeats the entire purpose of connected.
Thank you! Got my text messages back
Dec 23, 2015 10:36 AM
tippin
Aug 5, 2015 08:43 AM
