FS:: BNIB Kenwood KAC-8405 4/3/2-channel 720W amp
Category: Navigation & Audio
Price: $100
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, Classic Mini, Electrical
Location (Region): SouthEast
Item Condition: Brand New
I'm selling a BNIB Kenwood KAC-8405 4/3/2-channel 720W amp. I realized that I don't need a sophisticated sound system if I'm going to track the car. I put some infinity speakers in the car and it sounds perfect to me, no need for the amp. My loss is your gain.
Here's a link: http://www.onlinecarstereo.com/CarAu..._KAC-8405.aspx
SPECS:
KAC-8405 Car amplifier Power Output
- 60W X 4 @ 4 Ohms
- 90W X 4 @ 2 Ohms
- 180W x 2 [Bridged] @ 4 Ohms
- Class A/B 4-channel (stereo) car amplifier with MOSFET power supply
- LED power indicators
- 4/3/2 channel operation
- Speaker-level inputs
- Input sensitivity control
- Bass boost switch
- Short circuit, DC offset, overload, and thermal protection circuitry
- Signal sensing turn-on
- Cast aluminum heat sink design
- Built-in cooling fan
- Gold-plated RCA level inputs
- Gold-plated screw terminals
- Single side exposure of terminals for multi-installation
- Variable high-pass filter (50-200 Hz, 12 dB/octave)
- Variable low-pass filter (50-200 Hz, 12 dB/octave)
- Frequency response: 50-200 Hz
- Dimensions: 11"L x 2-5/16"H x 9-3/8"D
- UPC: 019048186485
- Weight: 9
I was goingbto put it in an aftermarket radio. I think that with the stock radio you would have to rewire things in the back ofthe radio and get an RCA cable conversion kit. Good aftermarket raeios are not that exepensive, probably better off getting a new radio, believe me, it was worth in mg opinion.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
