JCW Brembo sport brake kit with R121 Conical spoke wheels ???
Old Sep 15, 2013 | 05:21 PM
Angryriican66's Avatar
Angryriican66
I searched and searched and searched with no luck
Has anyone successfully installed the brake upgrade with these wheels?
And if so which spacers were need to achieve enough clearance for the front caliper??
Thanks in advance!!
Old Sep 15, 2013 | 08:20 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
A question I have been wondering about as well...
Old Sep 18, 2013 | 06:31 AM
Angryriican66
For anyone asking this question my brake kit came with the latest list of approved wheels and the R121 Conical's ARE on the list which all the information out there said differently. This just save me a good chunk of $$ and my brakes will go in this weekend!!
UPDATE to this, luckily I kept the H+R 5mm spacers and longer bolts since the wheel just barely touches the caliper!
Picture with 5mm spacer, it clears with about 4-5
Old Sep 18, 2013 | 09:32 AM
squawSkiBum
Moderator
Nice! Thanks for the update. Are you doing the install yourself? Let us know how it all works out, and what the deal is on reprogramming the DSC.
Old Sep 19, 2013 | 02:05 PM
They must have updated the list. Thanks for the post. Congrats on the new JCW brake system.
Here is a Link to the older install PDF : Click Here
JCW 4 Piston Sport Brake Kit Retrofit - Priced As Kit
http://www.ecstuning.com/Search/SiteSearch/34110432802/
The coding afterwards is to change the dynamics and maybe dial back the ABS so its not so aggressive.
Old Sep 19, 2013 | 03:04 PM
Angryriican66
Yes, if it goes smooth I'll do a write up with Pictures. I Already went thru everything that has to be removed and it is very straight forward and no special tools that I don't have. Now that I know I don't have to worry about wheel fitment(I was going to go the trial and error route with spacers) it should be a few hours tops.
Old Sep 19, 2013 | 04:24 PM
Angryriican66
Will you be updating your website for compatible wheels?
I just bought a set of spacers from you(still in transit) I won't need I need to exchange for a different item, maybe some EBC Redstuff pads
Old Sep 20, 2013 | 04:55 AM
Yep,
Already updated. Thanks
The EBC Reds are very nice and great for the JCW Red Brake as they are very close to the Red and kind of blend into the caliper. The Green and Yellow really show contrast visually. Vary popular across the board from EBC.
EBC Redstuff Ceramic Pads Set Front JCW brembo 4 pot.
http://www.ecstuning.com/Search/SiteSearch/DP31854C/ES2609014/
EBC Redstuff Ceramic Pads Set - Rear
http://www.ecstuning.com/Search/SiteSearch/DP31931C/ES520508/
Good luck with the install and post up some pics, this JCW 4 Piston Brembo brake kit is a beauty.
Old Sep 24, 2013 | 02:14 PM
Angryriican66
Updated bump for fitment, you actually will need a 5mm spacer to make it work!
Old Sep 24, 2013 | 02:23 PM
So it comes a little close with the caliper, on the face. Yea, good thing you kept them. Are you going to space the rear for a flush look say 5mm or 15mm?
I have updated the part, thanks for your help.
Old Sep 24, 2013 | 02:27 PM
Angryriican66
No problem, love being a guinea pig
I'm debating on adding rear spacers, it makes sense to just do the rears to so I'll see. Now that I don't need new wheels I have to see where I'll spend the saved cash
Old Mar 28, 2015 | 03:27 PM
eRock's Avatar
eRock
Reprogramming?
What about the reprogramming? Is it really necessary? Will the DSC apply too much braking force or something?
Old Mar 30, 2015 | 06:12 AM
You can have it done. Its to just to change the DCS and the ABS a bit so it dials it back a bit is what I have heard, as this brake package is more aggressive.
NYXF56JCW
Nov 17, 2024 05:06 AM
Dec 23, 2015 10:36 AM
phrza81
Oct 10, 2015 11:37 PM
elightbo
Aug 17, 2015 01:50 PM
