Brake Pad options for the GP Caliper
So I read somewhere that the GP caliper is the same as the 135, but cant find any vendor selling performance pads for the GP - other than Way, of course-Has anyone used/bought high temp pads? Hawk DTC-30, 60 or 70 or Fedoros Ds3000?
I will be putting my Carbotech AX6 pads to the test this weekend at our 6th autocross. So far the bite / stopping power over OEM is unbelievable. Its hard to believe that a brake pad makes such a drastic difference. They are not quite like OEM but thats fine with me. If I commuted in this car a lot and was in stop and go traffic I guess lower performance quieter pad would be better.
I am sure that Carbotech can cut GP specific pads for you.
I only have the EBCs for the GP right now. I don't use Hawks as I've had too many problems with them.
Ferodo pads always seem to make too much noise, and are pricey.
For light track use I'd use the EBC yellows, they will handle the heat and are very rotor friendly.
The Redstuff pads are great for daily use.
We also have some Textar pads which is the company that makes the OEM GP pads, but they are just the same as the stock pads.
Any track videos of you in action?
Here is the list of BMW 6 piston pads that fit the GP front brakes. The rear pads follow the same as the rears. I would just match them of course. Hawk HPS and Redstuff are good for some track days and street use. For more track the yellows or even HT 10 +, higher on the hawks they can take some time to warm up.
Here is what we have.
Front Brake Pad Set MINI GP 6 piston
http://www.ecstuning.com/Search/SiteSearch/34106860642/
And the rears Which are the same as the JCW.
http://www.ecstuning.com/Search/SiteSearch/34216778327/
Thanks and let see some of those track day pics
Thanks! Excelent info.. Do you guys carry the DTC 30?
You are welcome, we added the DTC 30 to the list. Click the front pad list again.
Part numbers please
Guys I recomend to regard EBC Bluestuff NDX DP51995NDX. It should be better than yellow in everything, may be except dust. Do not be confused that it is positioned as "Full Race" - Bluestuff is pretty good when cold, no problem at all! As DD pads Bluestuff is better than DS2500 which I changed on Blue (my brakes are not GP). I also used Yellow but on other calipers.
ASH930 - We ship international.
See the links above and just add it to you cart, then choose the shipping method or service you want.
Cheers
ASH930 - The DTC-60 are a track pad ( and aggressive ) where the the EBC yellows can be for track and street, just make sure your get the same type for the front and back.
I'm thinking of getting a dedicated set of pads and rotors for the track…..
Has anyone noticed with the GP that with hard braking with street driving, you push down the pedal and you reach a point where that's basically it? It's like I'm pushing against something, but it's not giving anymore braking. It's like you reach a point where the linear - ness is basically gone.
I put the EBC yellows on awhile back. Can't say I'm impressed. I just wonder if I need better fluid or a larger master cylinder, or different brake set? It's unnerving
when you push the brakes hard and there's nothing really there after a certain point.
In contrast, I own a Cayman R and the GP brakes are more grabby and would be better than the Cayman if I didn't run into the above sometimes. The Cayman brakes feel mushy and you really have to push hard, but it basically does delivers.
I wonder if this is partly related to the GP master cylinder, which is different from the master cylinder on every other mini.
I have run the GP2 on the street and track both completely stock and also with pagid RS29 pads and uprated fluid and braided lines. Both combinations had a very hard pedal feel, which lacks some modulation. It sure does stop well, but not much feel.
Interestingly I have put a set of GP calipers on my JCW racecar, and have retained the stock JCW master cylinder. This combination has a much more progressive feel and modulation.
BTW, this is entirely down to driver preference to some degree. I actually like a quite soft pedal with reasonable travel, but one that does bite if you stomp it hard. Other racers demand a rock hard pedal feel
Any brake pad recommendations for heavy/aggressive street/lite track?
Just wondering what the next step would be.
Carbotech have a whole range of compounds for the 135 front, which fit the GP caliper, part numer CT1371. Something like the XP8 compound might be good for what you describe. http://www.ctbrakes.com/
An interesting article about braided vs. normal brake lines - http://www.autospeed.com/cms/article.html?&A=2679
Anyone have experience with the Carbotech AX6 or the Hawk HPS brake pads?
Which is better for good braking for mainly street driving? I live in AZ so cold temps are really not a problem. Dust and noise doesn't really bother me too much either. I'm leaning towards Carbotech #1371 AX6 pads.
Best place to buy these?
Thanks!
Thanks!
penguinhomey
Aug 17, 2015 01:33 PM
