R60 Does the factory roof rack of a clubman fit a countryman with roof rails??
nope. won't fit. i own both. clubman uses rain gutter mount. countryman has a custom base plate that is contoured to match the countryman rails. profiles are totally different.
There's two types on the Clubman. The rain gutter that you mentioned, but you can also get roof rails from the factory so it's closer to how the countryman is. Still not compatible though.
Generally, I think you will find that nothing on the Austrian MINIs is compatible with the English MINIs. They're concieved and birthed way to close too the Home Land.
There is one for the Clubman with roof rails and one without roof rails.
R55 MINI Clubman Roof Rack Base Bars *With out roof railing.
( also referred to as attaching to the rain gutters )
http://www.ecstuning.com/Search/SiteSearch/82712149225/
R55 MINI Clubman Roof Rack Base Bars * With roof railing.
http://www.ecstuning.com/Search/SiteSearch/82710435867/
Here is the Countryman version with roof rails.
R60 Countryman Roof Rack Base Bars
http://www.ecstuning.com/Search/SiteSearch/82712148014/
They look close but I believe they will not fit dimensions.
1chaos52
Aug 24, 2015 01:28 PM
Aug 12, 2015 01:24 PM
