R60 Does the factory roof rack of a clubman fit a countryman with roof rails??
Old Sep 10, 2013 | 02:21 PM
mrgentleminh's Avatar
mrgentleminh
anyone know?
Old Sep 10, 2013 | 05:19 PM
chrunck's Avatar
chrunck
Pretty sure the answer is no since the rails are quite different.
Old Sep 11, 2013 | 06:00 AM
MyroMini's Avatar
MyroMini
no, it does not (i know, I sold my clubby and I am now driving a CM
Anchoring is not the same, as the CM rails are flush mounted.
Old Sep 11, 2013 | 10:33 AM
tstizzle's Avatar
tstizzle
anyone know?
nope. won't fit. i own both. clubman uses rain gutter mount. countryman has a custom base plate that is contoured to match the countryman rails. profiles are totally different.
Old Sep 11, 2013 | 11:37 AM
chrunck's Avatar
chrunck
There's two types on the Clubman. The rain gutter that you mentioned, but you can also get roof rails from the factory so it's closer to how the countryman is. Still not compatible though.
Old Sep 11, 2013 | 12:40 PM
Sealy's Avatar
Sealy
Generally, I think you will find that nothing on the Austrian MINIs is compatible with the English MINIs. They're concieved and birthed way to close too the Home Land.
Old Sep 11, 2013 | 01:41 PM
There is one for the Clubman with roof rails and one without roof rails.
R55 MINI Clubman Roof Rack Base Bars *With out roof railing.
( also referred to as attaching to the rain gutters )
http://www.ecstuning.com/Search/SiteSearch/82712149225/
R55 MINI Clubman Roof Rack Base Bars * With roof railing.
http://www.ecstuning.com/Search/SiteSearch/82710435867/
Here is the Countryman version with roof rails.
R60 Countryman Roof Rack Base Bars
http://www.ecstuning.com/Search/SiteSearch/82712148014/
They look close but I believe they will not fit dimensions.
Old Sep 12, 2013 | 06:38 AM
mbabischkin's Avatar
mbabischkin
In the pictures the inside mounting point on the Clubman rack for roof rails is shorter than the Countryman rack...
Old Sep 12, 2013 | 08:17 AM
MyroMini's Avatar
MyroMini
trust me, it does not fit. I tried.
Aside from the mounting point and the rails being completely different, the clubman rack bars are shorter than the ones for the CM
1chaos52
Aug 24, 2015 01:28 PM
Aug 13, 2015 12:57 PM
Aug 13, 2015 12:56 PM
Aug 12, 2015 01:24 PM
