Engine whine or rattle noise
Old Sep 9, 2013 | 08:58 AM
rberga1's Avatar
rberga1
Hey Guys,
I have a 2004 Mini Cooper S with 111,000 miles on it. I was driving on the expressway on the way home when I noticed a whine/rattle coming form the engine compartment. There is no check engine light and the car/engine still seems to runs fine. I was able to drive home which was another 5 miles away.
I took a video of it and posted to youtube. Here it is below. You'll notice the whine/rattle matches engine revs. Any ideas on what the problem may be?
Old Sep 9, 2013 | 01:25 PM
element's Avatar
element
sounds like your supercharger\waterpump.. if you haven't serviced that area before it's time with your mileage!
Old Sep 9, 2013 | 06:40 PM
Da_Ghost's Avatar
Da_Ghost
Buy a cheap stethoscope (one for mechanics of course), it will at least help you pinpoint the exact source. Personally, I'm not familiar with this sound, but when my alternator started making an awful sound, I had to stop on the side of the road and couldn't tell what was making the noise. With a stethoscope, it's only a matter of hearing where the sound is coming from and go from there.
Old Sep 10, 2013 | 05:40 AM
jamez's Avatar
jamez
A length of tubing stuck up to your ear can also work for a stethoscope.
I can't say I've heard that sound, but keep us informed of it's location and maybe we can help further.
Old Sep 10, 2013 | 06:05 AM
Helix13mini's Avatar
Helix13mini
Actually tubing is better for locating air leaks. You can make a home-made stethoscope with a long prybar or really long screwdriver or other rigid tool. Place one end on your ear and the other on various parts of the motor to locate the loudest sounds source. BE CAREFUL NOT TO TOUCH MOVING PARTS OR GET HAIR CAUGHT IN SPINNING PULLEYS. That would smart.
Old Sep 10, 2013 | 06:40 AM
rberga1's Avatar
rberga1
Thanks for the info guys...the sounds seems to be most loudest by the alternator/front passenger side.
What is the sound of the supercharger/water pump issue?
Old Sep 10, 2013 | 06:00 PM
Da_Ghost's Avatar
Da_Ghost
Usually it's a bit like valve ticking, faint knocking, hard to describe. Here's a nice vid I found that gives a good idea:
And as for reference, here's my own car, 05 S with a bad alternator bearing (keep in mind that noise can varies depending on what part of the component is going bad):
Old Sep 17, 2013 | 09:07 PM
rberga1's Avatar
rberga1
Well I used my long pry bar and put it against a bunch of things in the engine and the sound is most pronounced on the alternator. I will order a new alternator and install it soon.
Old Sep 23, 2013 | 04:33 PM
rberga1's Avatar
rberga1
So the issue was my alternator! After replacing it, all is good now.
Since I had a lot of things in the front off, I removed the supercharger and checked the oil and the back part had plenty of oil in it...so did the front but the front oil was all black. I ended up draining the front and replacing with new GM oil. I also replaced the waterpump eventhough it wasn't needed.
I had a pretty bad oil leak at the lower oil dipstick housing, the crankshaft position sensor, the oil pan, and the valve cover so I replaced the o-rings and gaskets for them.
Old Nov 13, 2013 | 07:37 AM
minimike1!'s Avatar
minimike1!
I developed a short whine when I first crank up after sitting a few days. It goes away in about a second. didn't notice this before I changed the oil last time. Not sure if there is a connection? Levell is good.
Melvinyip
Apr 17, 2020 09:28 AM
woodstudio
Mar 15, 2020 08:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
elightbo
Aug 17, 2015 01:50 PM
