secondart air pump fault code. were is the secondary air pump?
Old Sep 8, 2013 | 10:30 AM
screwed36coupe's Avatar
screwed36coupe
Hello. Ive wiped the faults from the ecu and this code,p1477 keeps logging. Ive also got a.strange popping noise comming from the engine. I read the socondary air pump can make that sound and that follows what the fault is saying
Iv searched forum and didnt find what i was looking for, i need to know were this secondary air pump is located
Old Sep 9, 2013 | 03:50 AM
mrbean's Avatar
mrbean
You can search all you want, but you won't find a secondary air pump on your car. It doesn't have one.
Old Sep 9, 2013 | 05:22 AM
screwed36coupe
Awesome. Why the fault code then? Can this code apply to somthing else?
Old Sep 9, 2013 | 06:25 AM
Da_Ghost's Avatar
Da_Ghost
There is an air pump on Minis, it's the pump used to pressurized the tank to check for leaks in the evap system. Number 3 in the pic:
http://www.realoem.com/bmw/showparts...26&hg=16&fg=10
I don't know about others, but I can hear mine when it's running (rear seat delete probably helps a bit)
Old Sep 9, 2013 | 08:51 AM
I think you are talking about the leak diagnose pump located by the fuel tank.
There is a version for pre 7/2004 production
#3 in the diagram Leak Diagnosis Pump Part# 16136801158
http://www.ecstuning.com/Search/SiteSearch/16136801158/
and post 7/2004 production
#2 Leak Diagnosis Pump Part # 16117158983
http://www.ecstuning.com/Search/SiteSearch/16117158983/
Here is a link , others have found leaks in the line up in front of the engine , its model specific to the breather line up near the engine bay on top of the engine. I don't know your model or year as you did not state it. But I know you are a Gen 1 MINI.
https://www.northamericanmotoring.co...stic-pump.html
Thanks and hope that helps.
Old Dec 7, 2014 | 01:04 PM
illbegotten's Avatar
illbegotten
Maybe someone can help me. I had a mechanic tell me I am missing a hose on my secondary air pump. He said the pump was under the turbo and you could see it from under the car... What is there and where would the hose lead?
JPRI
May 8, 2016 02:19 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
scottrn
Aug 22, 2015 07:26 PM
Dsinkster
Aug 17, 2015 03:24 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
