Interior/Exterior Rear seat delete with extra storage access
Old Sep 5, 2013 | 10:20 AM
ARTR53's Avatar
ARTR53
Picked up the MINI last Friday already knew that the rear seat was not going to be in use much at all so I went ahead and did a rear seat delete but wanted to use the extra storage under the board.
Materials needed:
- Scissor to cut the foam and fabric
- MDF board from Home depot or so
- 3M Headliner glue spray (picture below)
- 2x 1/2" Bolt/nut/lock washer
- 4x Hinge rings (to slide the bolts through using the existing rings in car)
1. Take the seats out obviously
2. Take measurements for the board, cut it out and test fit before doing anything else.
3. Bolt on the hinge rings on the board
4. 3M glue the foam on the board
Old Sep 6, 2013 | 10:04 AM
ARTR53's Avatar
ARTR53
5. Fabric on, then press it with something heavy, used a tire to push it down and wait 30ish minutes.
6. Clean up the edges, staple the fabric on, cut around the hinges.
7. Bolt up the board in the car!
8. DONE!
Old Sep 6, 2013 | 10:05 AM
ARTR53's Avatar
ARTR53
Optional: Foam in the storage area (did that to reduce the road noise and to reduce the rattling when items are in the storage area)
Old Sep 6, 2013 | 10:44 AM
JAB 67's Avatar
JAB 67
I don't think that is cardboard. More like fibreboard.
Old Sep 6, 2013 | 11:51 AM
ARTR53's Avatar
ARTR53
MDF board*
Old Sep 6, 2013 | 12:11 PM
InjectedGT's Avatar
InjectedGT
Originally Posted by ARTR53
MDF board*
MDF stands for Medium Density Fiberboard. He isn't wrong.....
Old Sep 7, 2013 | 10:44 AM
AGR53's Avatar
AGR53
Awesome!
How/where did you bolt the hinges to the car?
Old Sep 12, 2013 | 07:19 AM
ARTR53's Avatar
ARTR53
Originally Posted by AGR53
Awesome!
Bolted it to the existing hinges that were already there to hold the rear seats, if you take the seats out, it should be there.
Old Sep 12, 2013 | 07:33 AM
bahawton's Avatar
bahawton
The hinge concept is a great idea!
Old Sep 12, 2013 | 04:55 PM
watson 29's Avatar
watson 29
Looks real good.
Excellent use of the legacy wheel.
Old Sep 17, 2013 | 07:48 PM
watson 29's Avatar
watson 29
After realizing how easy it is to put these seats in and out, I am curious where you got your carpeting materials from? If I can do this for cheap I'll do it.
Old Sep 21, 2013 | 04:08 PM
ARTR53's Avatar
ARTR53
Thanks! It was my first idea when I took the seats out.. I was like I got to use those!
Originally Posted by watson 29
Looks real good.
Thanks and yes great use of the LGT rims ha
Got it from a local fabric store (Joann would be great), I got a piece of foam and fabric there. The total cost was about $30, def worth it.
Old Sep 21, 2013 | 04:29 PM
MotorWorf's Avatar
MotorWorf
You coulda just bought a Clubman and be swimming in space just by adding a piece of carpet ($8 @ Home Depot and rubber backed) while still keeping your seats if ever needed and little bit of access from the side (behind seats with the 3rd door. Also, the MINI Cooper and MINI Cooper Clubman are essentially the same from the 2 side doors forward--they only differ from the rear of the two front seats to the back.
Attached Thumbnails Rear seat delete with extra storage access-mini-rear-carpeted.jpg
Old Sep 23, 2013 | 06:17 PM
watson 29's Avatar
watson 29
yes, but I bought my s quickly as I much needed a new vehicle and got it for a steal.. so...
Most of the time I have more room than I'll use, but from time to time I stop by on of our suppliers to pick up some tv's for work since I live fairly close and it'd be nice to have.
Old Dec 26, 2013 | 07:38 PM
OdzBodkinz's Avatar
OdzBodkinz
Hey this looks great. I like your idea for the hinges. I did a rear seat delete over the summer, and I may retrofit mine to accommodate the hinge idea. Here's mine:
https://www.northamericanmotoring.co...te-my-way.html
Old Jan 1, 2014 | 03:28 PM
ARTR53's Avatar
ARTR53
Looks nice! The hinge part is what everyone loves about, it allows easier access to the extra small spot under the MDF.
Old Apr 17, 2014 | 09:04 AM
Mr Moe's Avatar
Mr Moe
Great idea! Contemplating on a DIY rear seat delete too. Just wondering... does the hinge rattle?
Old May 18, 2014 | 05:27 PM
codylefever6's Avatar
codylefever6
Im currently measuring out my rear seat delete. Nicely done with the hinges.
mishanja
Jun 22, 2016 09:59 AM
06BLKchrgd
GP Talk (2006)
Feb 14, 2016 12:07 AM
Mini'mon
Aug 26, 2015 01:02 PM
mini4thewini
Aug 19, 2015 05:18 PM
